It is currently Wed Oct 07, 2026 3:13 pm
Post Posted: Fri Jan 28, 2011 2:38 am
hey guys a while ago i changed my timing belt and fan belt car was running perfect still feel like is but it seems sometimes the car will squeal now i think its the fan belt that needs ajusting ..how tight is to tight ..
Post Posted: Fri Jan 28, 2011 3:08 am
I usually set it so it deflects about 10mm, that's what the manual says from memory.
Post Posted: Fri Jan 28, 2011 3:11 am
and if it deflects that much and i still hear that noise ?
Vehicle: 2001 Jimny M13a
Post Posted: Fri Jan 28, 2011 5:44 am
I've got the same problem. There doesn't seem to be a way to adjust it very acurately other than wedging a big screwdriver in there to lever the alternator downwards while boing the bolt up. Mine barely deflects at all but still squeals.
I heard a bit of talcum powder can make it grip a bit better, I'm going to try that next.
Post Posted: Fri Jan 28, 2011 7:32 am
When it snap's..... :roll:
tighen it up, use a leaver to move the alt, forget all you have been told about belt's & go tighter, or it will squeal.
I have never snapped one & have tightened the bejebus out of em, 1/2 expecting the car to be back in the next day with no belt, 12 month's later & still going strong, there are suzuki's out there I fitted belt's to 5yr's ago still going strong..
Post Posted: Sat Jan 29, 2011 4:01 am
Buy a can of belt grip.
Robert
Post Posted: Sat Jan 29, 2011 6:05 am
Robert
why not, get Santa to deliver it...
Post Posted: Sat Jan 29, 2011 7:07 am
with my 110 amp alt i HAVE to replace my belt every service (5000km) or it wears out and squeels like a bitch
Post Posted: Mon Jan 31, 2011 6:49 am
steak_knife wrote:
tighen it up, use a leaver to move the alt, forget all you have been told about belt's & go tighter, or it will squeal...
That's good to know, I've loosened it, still sueels, tightened it, still squeals, I'm gonna wring it's neck now.
Post Posted: Mon Jan 31, 2011 7:06 am
all fixed :) thanks
Post Posted: Mon Jan 31, 2011 8:28 am
thats not the problem though, if its to tight it loads up the water pump bearing and the alt bearing and makes them noisy and fail prematurely.
Post Posted: Mon Jan 31, 2011 11:05 am
So tell me the problem, also tell me how much load is to mush for a bearing, cause I have seen suzuki's tightened to this Suzuki approved method go over 270k on the original pump....my ole Gv being on of em..
Vehicle: 91 sierra
Post Posted: Mon Jan 31, 2011 11:06 am
the way i fixed mine is stated the car let it idle and held a plain candle to each side of the belt until the squeal went away, has fixed the problem for a year so far :)
K.I.T
Knight rider
d(^_^)b
Post Posted: Mon Jan 31, 2011 11:12 am
^^ dry lube does the same thing, but leave's a mess on the bonnet.
Vehicle: 91 sierra
Post Posted: Mon Jan 31, 2011 11:20 am
yeah but you have to by that
K.I.T
Knight rider
d(^_^)b
Post Posted: Mon Jan 31, 2011 11:22 am
:? did you pull the candle out of your butt??? :?
Vehicle: 91 sierra
Post Posted: Mon Jan 31, 2011 11:23 am
you wish nah the ex left them behind when she left
K.I.T
Knight rider
d(^_^)b
Users browsing this forum: No registered users and 201 guests
