Page 1 of 1
[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
buzbox
Joined: Thu Jul 16, 2009 11:30 pm Posts: 3600 Location: Wollongong NSW
Vehicle: LWB Sierra & XL7
 Posted: Sun Jan 30, 2011 11:04 pm |
A couple of weeks ago I replaced the timing belt water pump, cam and crank seals.
I thought it would've been the crank seal that was leaking but now It's leaking more oil than before.
I've taken it to a mechanic and he tells me it's the oil pump, He said he removed a bolt that hold on the power steering bracket and the leak stops but when the the bolt is in it leaks, I find it hard to believe so I'm taking it to another mechanic for a second opinion.
What do you guy's think it could be...
royce
 Posted: Sun Jan 30, 2011 11:20 pm |
OOOO I know this one
the bolt that makes it leak is too long, stick one 5mm shorter in
buzbox
 Posted: Sun Jan 30, 2011 11:24 pm |
Alright I'll give it a crack.
buzbox
 Posted: Tue Feb 01, 2011 12:04 am |
very weird, this is the bolt in question, I've let the engine run for a bit and no leaks. I wonder what is causing it, there is no oil on this bolt.
royce
 Posted: Tue Feb 01, 2011 12:06 am |
I dont know why or what makes it do it or what its pushing on, just had the same problem with Bruces when we put power steer in it
buzbox
 Posted: Tue Feb 01, 2011 12:39 am |
Well I got another bolt and chopped it down, just to be sure I put some gasket goo on it.
fingers crossed.
buzbox
 Posted: Tue Feb 01, 2011 3:07 am |
Thanks big time Royce, it worked !!!
Page 1 of 1
[ 7 posts ] |
Users browsing this forum: Brenno, Google [Bot] and 193 guests
