http://auszookers.com/forum/
92 sierra 1.6 conversion question
http://auszookers.com/forum/viewtopic.php?f=5&t=18726
Page 1 of 2
Author:  lumpy_zook [ Mon Jan 31, 2011 10:24 pm ]
Post subject:  92 sierra 1.6 conversion question
hello.
bought a 92 sierra that was drowned for $1000 and was told motor is still fine, but its dead.
have found a 1.6 out of a vitara (i assume) with gearbox/transfer case in one and attatched to the motor. can buy motor on its own no gearbox.
just wondering if i can use the gearbox with the transfer case in one with my stock W/T drive shafts or would it be better to run my 1.3 gearbox with a lowrange adaptor plate?
custom fab for the crossmembers is not an issue.
and can i use the 1.6 clutch with the 1.3 gearbox if i have to retain it?
thankyou in advance!
lumpy. :D
Author:  Fatzook [ Mon Jan 31, 2011 10:48 pm ]
Post subject:  Re: 92 sierra 1.6 conversion question
Hi Lump,
Is the 1.6 a carby or EFI?
You can fit the vit engine and gearbox, but lose the transfercase. You will need to flare the tranny tunnel slightly to fit the vit box, and make a new x-member. You will need to shorten the jackshaft too. The sierra transfer will stay where it is.
All this means no adaptor plates, or weak 1.3 gearbox, or sierra clutches etc.
If you keep the 1.3 gearbox you will need to use the 1.3 clutch and flywheel.
Peter
Author:  lumpy_zook [ Mon Jan 31, 2011 10:58 pm ]
well, thats waht i thought but when i was looking at the engine (it still had the gearbox attatched) the gearbox and transfer case was one peice. similar to the likes of patrol etc.
if it was a seprate gearbox and transfer i would be fitting it now :P
also, its a efi 16v motor. was told they are wrecking a sierra. but as far as my knowledge there wasnt a sierra that came out with a 1.6?
any chance some one has a 1.6 gearbox available to sell? seprate for use with my 92 transfer case? a stronger box sounds good.
thanks
Author:  lumpy_zook [ Mon Jan 31, 2011 11:00 pm ]
btw, im reading the step by step guide on 1.6 conversions now. just my gearbox issues im unsure about. thanks
**edit. ok, found out what car it came from.
1997 suzuki vitara jx. i assume this is still sutable for the conversion?
Author:  zukmeista [ Tue Feb 01, 2011 12:37 am ]
It is a one piece unit, but it can be separated. Transfer bolts onto gearbox I think. :wink:
Author:  lumpy_zook [ Tue Feb 01, 2011 12:40 am ]
ok awsome. so what do i do once the transfer case is separated from the gearbox so i can use it as a normal gearbox?
(as in where the jackshaft goes?)
or doesnt it work like that? i need it to run like the normal 1.3 separate gearbox does.
thanks.
Author:  shane1992 [ Tue Feb 01, 2011 1:14 am ]
thanks.
What Fatzook said?
Hi Lump,
Peter
I have a 1.6L gear box if you wann buy it? Im about to do the 1.6 Conversion to but sticking with the 1.3 box
Author:  lumpy_zook [ Tue Feb 01, 2011 1:17 am ]
i can get the gearbox when i get the motor.
the only thing i dont understand is once i unbolt the transfer case will the jack shaft just go into whats left of the gearbox?
or is there something else i have to do to it before i can use it?
how much for the gearbox you offered shane? is it the same style of box as the one im talking about? or one like the 1.3 with a seprate transfer case?
Author:  Fatzook [ Tue Feb 01, 2011 1:21 am ]
Here is a link to my setup. 1.6 vit box. You can just see the jackshaft.
http://auszookers.com/index.php?name=Forums&file=viewtopic&t=9206&postdays=0&postorder=asc&start=210
Author:  Fatzook [ Tue Feb 01, 2011 1:24 am ]
I don't have a pic on hand but if you split the gearbox and transfercase appart, you can see that both are sealed and there is an extension chamber built into the transfercase. The back of the gearbox has a seal for the jackshaft to slip into. No further work is required.
Author:  shane1992 [ Tue Feb 01, 2011 1:27 am ]
Fair enough.
Im not to sure on that, as ive never taken a Transfercase off and had a look. But it can be done, may just have to get different fittings for the jack shaft and get it resized.
Yeah its got the tansfercase bolted to it. Probabyl about $200-$250 for it.
shane
Author:  lumpy_zook [ Tue Feb 01, 2011 2:32 am ]
ahh so, once the transfer case is removed there will be a shaft sticking out that the jack shaft goes on, and you just leave the box looking like that? with where the transfer case goes on just bare?
that makes sence to me now. sorry for the head fk over this.. this is first time dealing with 4wd's and that..
im into imports.
thanks alot for your help.
Author:  Fatzook [ Tue Feb 01, 2011 2:34 am ]
I'll get some pics
Author:  lumpy_zook [ Tue Feb 01, 2011 2:44 am ]
ok that will be great. i didnt see your reply above shanes, Fatzook, it makes sence to me now, and i will be buying the gearbox with the motor.
but some pics would be good so i know what il doing.
whats the clearance like with the sump? no body lift no spring lift, just some extended shackles.
will do body lift if needed.
Author:  skyman [ Thu Feb 03, 2011 4:13 am ]
Since we're on the topic of gear vit gear boxes, what's the gear ratio like on those 5 speeds? Is it close to a Sierra's or different?
I would be nice to have a higher 5th gear for the freeway here.
Author:  Fatzook [ Thu Feb 03, 2011 6:49 am ]
Exactly the same as sammi 5sp. :(
Author:  skyman [ Thu Feb 03, 2011 7:31 am ]
bummer, was hoping for a different ratio or two. I just picked up a 5:14 case to replace my 4:1. It's bit lower in hi range, but the low is going to be nice.
The problem is I am as low as I want to go in high already, so even a little lower is too much there. Maye I'll go back to the stock 3:73's if it's too much.
I have a vit 5 speed and case I was going to make into a kicker3 one of these days. So that's why I was askin' about the ratios. Was hoping for a high 5th :?
Oh well at least it's a bit more stout of a transmission :mrgreen:
Author:  Fatzook [ Thu Feb 03, 2011 7:39 am ]
As far as I can see thats one of the only 2 benifits. The other being a larger clutch.
Author:  steak_knife [ Thu Feb 03, 2011 8:11 am ]
& flying wheel, not an advantage, cause it doesn't spin up as quick..
Author:  stiky [ Thu Feb 03, 2011 9:18 am ]
my 1.6 efi idels at 1500 rpm would his be cuz of the 1.3 flyweel being light?
Author:  Fatzook [ Thu Feb 03, 2011 9:20 am ]
Doesn't slow down as quick either :wink:
Author:  mondo [ Thu Feb 03, 2011 9:21 am ]
does it always idle at 1500rpm or does it come down after a few minutes?
Author:  Fatzook [ Thu Feb 03, 2011 9:23 am ]
No.
A lighter flywheel will allow the motor to rev quicker. It also allows it to wash off speed quicker. In a 4wd thats not a great thing. For example if you are trying to scale a rock, the revs will drop faster as you push up against it with a lighter flywheel, increasing the chances of stalling. A heavy flywheel has more rotational mass, and is harder to slow down. So the same rock then becomes less of an obstacle for the motor.
Author:  stiky [ Thu Feb 03, 2011 9:23 am ]
always
Author:  Fatzook [ Thu Feb 03, 2011 9:25 am ]
stiky wrote:
always
Adjust the idle speed down.
Author:  mondo [ Thu Feb 03, 2011 9:28 am ]
stiky wrote:
always
did this happen to any of your 1.6 sierra's ? mine was doing the same i just didnt leave it on long enough to find out if it was just like a cold start function or something like that?
Author:  Fatzook [ Thu Feb 03, 2011 9:30 am ]
mondo wrote:
stiky wrote:
always
Yeah I had to play with my idle speed. Seemed to fix my problem so I didn't look any further :?
Author:  stiky [ Thu Feb 03, 2011 9:32 am ]
ajst the idle down how?
Author:  mondo [ Thu Feb 03, 2011 9:39 am ]
pretty sure there's a big bolt with a flat head top on the throttle body housing somewhere that you adjust
Author:  stiky [ Thu Feb 03, 2011 9:49 am ]
is there an ideal rpm for idle ????
Page 1 of 2 All times are UTC + 9:30 hours
