It is currently Wed Oct 07, 2026 1:53 am
Post Posted: Tue Feb 01, 2011 9:13 am
as the title states my 92 widetrack flat to the floor 5th gear does max og 95 on the highway and im runnibg 31'' muddies
Post Posted: Tue Feb 01, 2011 9:15 am
have you done anything to the car gearing wise?
what rev's are you doing while on the freeway?
Post Posted: Tue Feb 01, 2011 9:16 am
Is that on the speed?? Or a gps unit
Got any transfer gears or diff gears in it??
Mine use to run out of puff at about the same point till i put the 6.5s in then was able to wind it out to 140 before i backed off
Post Posted: Tue Feb 01, 2011 9:17 am
zook95 wrote:
31'' muddies
Firstly, if you're running 31s then 95 on the speedo is 110 when corrected for tyre size...
Secondly, 31s are much bigger that stock. Correct the gearing and she'll go much better...
I want my old sig back :(
Post Posted: Tue Feb 01, 2011 9:18 am
im not to sure i havnt done it but the guy before me may havo how do i find out???
suzuki sj70+2 inch lift+ 2ich body lift+ el falcon
Post Posted: Tue Feb 01, 2011 9:21 am
tell us what RPM you're doing in a few gears for a few different speeds, we'll be able to tell you right away.
eg: 60km/hr, 4th = 2500rpm
etc.
Post Posted: Tue Feb 01, 2011 9:30 am
in 5th gear id say without not being sure approx 90-95 and around 4k-4,500k
only estimating but sure will take it for a test tomorow to have a look with all gears
Post Posted: Tue Feb 01, 2011 9:31 am
proberly should have got this info befoere i posted this trhead but meh..
Post Posted: Tue Feb 01, 2011 9:39 am
That is what mine revs at. I have 30's 6.5 gears and I do 100km/h @ approx the same revs. However, my speedo says 90km/h
Post Posted: Tue Feb 01, 2011 9:46 am
yeah based on that i'd say its definitely got some gearing done...
you'll most likely find that as ben stated above - 90km/hr with 31's is really 107km/hr... so 4000rpm at 107km/hr is more like a 6.5 transfercase - and most likely the sierra's horrible aerodynamics combined with the weight of 31" tyres is why you're struggling to go much faster.
this said though - a good exhaust and extractor set up (if it doesnt already have one) will make a great improvement, as will checking your leads, carby tuning, air filter etc.
Post Posted: Tue Feb 01, 2011 1:10 pm
1.6 conversion,
dodgy brothers mechanical
Post Posted: Tue Feb 01, 2011 6:51 pm
My old Sierra could sit on 120kmh without a problem I could drive over the gateway bridge at 90-95kmh in 4th and that was on 31's with s1 gears and 3.9 diff gears
It sounds like it needs a good tune and a decent exhaust/extractors
Users browsing this forum: maksims and 163 guests
