It is currently Sun Oct 25, 2026 10:27 am
Post Posted: Sat Feb 05, 2011 9:37 pm
i gave the axles to a mat to remove the bearings and he has nicked the axles with an oxy while cutting them off. it is only a very small cut about 2mm deep and 5mm long. will this effect the axle or are the stuffed?
Post Posted: Sat Feb 05, 2011 10:10 pm
Hey bud, I've nicked them before, it won't affect the performance of them, the only thing it will affect is the oil seal depending where the cut is, just bung a bit of auto silicone in the cut and around the bearing both sides around the axil and hope for the best
Sik as drover, 32" mongrels, 4age 20v, 2" sus, 2"
Post Posted: Sat Feb 05, 2011 10:57 pm
Waaaaaaaaaa nicked them with an oxy?
Lil Foot!
Post Posted: Sun Feb 06, 2011 7:35 am
NEVER use an oxy to remove a bearing..... The heat can severely affect the axle making it unsafe....
Post Posted: Sun Feb 06, 2011 7:49 am
I use an oxy :(
but i only use it on the retaining ring on a tiny flame and the ring just falls off without fucking the axles :wink:
Post Posted: Sun Feb 06, 2011 7:51 am
i just nick them with a grinder and cold chisel to brake it the rest
My Maruti build, Click WWW
Users browsing this forum: Google [Bot] and 170 guests
