It is currently Mon Sep 21, 2026 3:12 am
Post Posted: Fri Feb 04, 2011 10:46 pm
Thinking about a Hilux front diff but don't want the lift associated with SOA..
Anyone done it SUA?
Problems?
Pics?
Post Posted: Fri Feb 04, 2011 10:50 pm
wouldnt you have issues with the diff hitting the sump?
addressing the steering might also be tricky.
Post Posted: Fri Feb 04, 2011 10:55 pm
I'll be doing a chassis extension and pushing the diff quite a way forward so I don't think sump clearance will be a problem.
Steering box will be moved forward as well and possibly replaced with a bigger unit.
move your steering box forward, diff forward a bit, and coils :D
MQ diffs are suposed to be the sua option.....
Post Posted: Fri Feb 04, 2011 11:04 pm
but then he wont have gearin t match the vit rear.
what would you do for steering jas?60 nuckles maybe?
or fab up some mad ghetto steering arm similar to how preecys one is mounted in his vit thread 8)
Post Posted: Fri Feb 04, 2011 11:09 pm
Spua lux diff will need a special mount at the pumpkin end. The original spoa mounts have a notch in them to sit around the pumpkin. Then u bolts will be another issue.
Post Posted: Sat Feb 05, 2011 12:24 am
I have a Snake Racing arm thing, got it ages ago off a member here, that bolts to passenger side kingpin and supports drag link as well as tie rod. Should be able to use that.
As for box..... I dunno... Maybe hilux IFS or GQ :? :?
Post Posted: Sat Feb 05, 2011 12:32 am
Ifs lux's go on outside of chassis
Ideal is the landcruiser 60' and some others? forward pitman arm box, But most times it covers the chassis number where you mount it. Not ideal if going to be registered, Which won't be anyway being in qld..
Post Posted: Sat Feb 05, 2011 3:34 am
I used hilux ifs box on fatzook. Worked well.
Vehicle: I drive your mum
Post Posted: Sat Feb 05, 2011 3:39 am
Antt off OL did a SPUA lux didd on the front of his old oragne Vitara, i have some pics on an old PC, will see what i can dig up. Funny you mention this, i was looking at SPUA diff swap options just last night.
Layto....
Post Posted: Sat Feb 05, 2011 3:50 am
there is a thread on pirate4x4 in the suzuki section dealing with this.
http://pirate4x4.com/forum/showthread.php?t=852088
Post Posted: Sat Feb 05, 2011 5:14 am
There's a member here in Vic doing SPUA 60 series diffs as we speak. I had a look at some photos of it today - looks very good. It's tight for sure, (and WIIIDE with 8" rims and 35 12.5's) but looks good. (for an overdiffed car :wink: )
Post Posted: Sat Feb 05, 2011 12:37 pm
What springs are you going to run , Cheers Paul.
Post Posted: Sat Feb 05, 2011 8:13 pm
Hoping to keep the Zuk rears I currently have in the front....
Will eventually be 3/4/5 :? linked with air shocks like the rear but don't have the $$ at the moment.
Post Posted: Mon Mar 28, 2011 4:20 am
get the money and do it!!!
Post Posted: Mon Mar 28, 2011 5:31 am
Piss off idiot. :roll:
Users browsing this forum: No registered users and 192 guests
