It is currently Sun Oct 25, 2026 3:39 am
Post Posted: Mon Feb 07, 2011 8:16 am
Under certain conditions under brakes on a bumpy road the sj50 does the death wobbles .The steering wheel shakes uncontrollibly then it goes away ?
Have changed the steering damper with no results.
Any ideas would be appreciated. :?: :?: :?: :roll:
Smokey
Post Posted: Mon Feb 07, 2011 8:22 am
have a search for Sierra Death Wobbles.... pretty sure it's been covered before :wink:
http://auszookers.com/index.php?name=Fo ... th+wobbles
It can be a number of things, good luck.... you'll need it :P
Loose wheel bearings
Worn king pin bearings
Worn spring bushes
Can be any one or more of these three
Post Posted: Mon Feb 07, 2011 8:46 am
only while braking?
Vehicle: Suzukiless these days..
Post Posted: Mon Feb 07, 2011 9:07 am
warped disc rotors, Ball joints
goddamitmyspacebarsbrokenagain
Vehicle: I drive your mum
Post Posted: Mon Feb 07, 2011 9:10 am
Loose wheel bearings, loose U-bolts, wheel balance etc etc etc etc.
Layto....
Post Posted: Mon Feb 07, 2011 8:04 pm
only while braking?
:roll: Thats only when this happens but is triggered by a bump on braking but does not happen all the time.
Smokey
Post Posted: Mon Feb 07, 2011 8:10 pm
Not sure if im searching corectly but I get no results searching Sierra Death Wobbles maybee im not searching corectly :?: :?:
Post Posted: Tue Feb 08, 2011 1:27 am
i have thhe same, mine was loose/stretched u-bolts.
Users browsing this forum: Google [Bot] and 91 guests
