http://auszookers.com/forum/
5th Gear
http://auszookers.com/forum/viewtopic.php?f=5&t=18928
Author:  BigZook [ Tue Feb 08, 2011 3:58 am ]
Post subject:  5th Gear
Hello Zookers,
I like to start off with how awesome everyones rides are on this forum!!!
Now to the question I need answered I have a 1974 Suzuki Sierra with a F10A 1L engine, it only comes with 4 speed I was wondering if its possible to change the gearbox to a 5 speed?
If it is possible does it require alot of modifications?
Thanks guys
Author:  tanshi [ Tue Feb 08, 2011 4:00 am ]
Post subject:  Re: 5th Gear
Just to clarify.
1974 would make it an LJ series suzuki, at that age probably an LJ50
either that or its a type O and you meant 1984?
Author:  Rusho [ Tue Feb 08, 2011 4:00 am ]
Im pretty sure it's possible, but mods do need to be done.
Author:  Ben_Sierra [ Tue Feb 08, 2011 4:14 am ]
tanshi wrote:
Just to clarify.
If its '74 it'd be an LJ20, with a 359cc, two stroke FB engine...
Author:  tanshi [ Tue Feb 08, 2011 4:16 am ]
lj50s were released jan 74
Author:  Ben_Sierra [ Tue Feb 08, 2011 4:18 am ]
AFAIK LJ50s were released in '76...
Author:  tanshi [ Tue Feb 08, 2011 4:19 am ]
either way there are options for a 5 speed.
if its a sierra the late 1 litre sierra did come out with a 5 speed. also the maruti 5 speed will fit i believe.
if its is an LJ you can make a hybrid box using a carry 5 speed. there is a write up around here some where on it.
Author:  tanshi [ Tue Feb 08, 2011 4:24 am ]
I am 99 percent sure i know guys with older ones than that. be makes little difference
Author:  5ierra [ Tue Feb 08, 2011 4:30 am ]
Info i have foudn said the LJ50 was released in 74 when the KEI class rules in japan changed. Was released as the Jimny 550 & LJ50
Author:  BigZook [ Tue Feb 08, 2011 9:10 am ]
Sorry guys I've provided the wrong information :oops: going from the plate under the hood it's a:
1984 Suzuki Sierra SJ40V F10A Engine 970CC
Author:  303zuke [ Tue Feb 08, 2011 11:34 am ]
1984 is the changeover between a Type 2 and Type 3 SJ40. If you have a full width plastic dashboard (T3), it is fairly straightforward to rebuild your box as a 5 speed using the internals from a 1.3lt Sierra.
If you have a metal dash with plastic just around the instruments (T2), then you will have to source a later 1.0lt box PLUS the 5 speed internals.
Author:  BigZook [ Wed Feb 09, 2011 1:06 am ]
303zuke, i have the metal dash with the plastic covers on both ends of the dash. Do you know if it's going to bolt staight on or do I have to do some mods?
Author:  303zuke [ Wed Feb 09, 2011 12:24 pm ]
Oh no, you will have some mods. :cry:
Once you have sourced the later box and assembled the 5 speed internals in it (remeber to use the Input shaft from the late 4 speed to match the clutch), It will bolt directly onto the back of the engine. You will need to dick around with the rear gearbox support as they will be different between the early/late boxes, and you may need to gently panelbeat part of the Trans tunnel as the later box is wider and can foul the bodywork. You will also need a larger sliding yoke for the back of the gearbox, as the later box has a larger shaft/spline size.
