It is currently Tue Oct 20, 2026 1:07 am
Post Posted: Tue Feb 08, 2011 8:51 am
What is the process to have a body lift approved in qld? Does it just need a modification plate?
I want to fit 2'' max to clear 31's on my vitara
Post Posted: Tue Feb 08, 2011 9:00 am
From memory you have to apply to d.o.t before you do the bodylift..
Post Posted: Tue Feb 08, 2011 9:17 am
I might call qt tommorrow and see what they say. Is it worth the trouble to have it approved
Post Posted: Tue Feb 08, 2011 9:22 am
Never actually been through it so have no idea how much of a hassle it really is...
Post Posted: Tue Feb 08, 2011 9:47 am
PM Just_cruizin.
He will send you the correct paperwork to fill out.
You need to send that in, then wait till they send it back to you to say yes you can fit it. Then fit it. THen book in to get it checked and they then stamp it (paperwork that is) and you keep that in your glovebox
Yes it worth getting it done as if you have a crash you might have probs if they ask if you have it approved or if you get pulled up by cops or transport. I have been pulled up and I showed them the paperwork and all was good.
Post Posted: Tue Feb 08, 2011 9:51 am
Bruce wrote:
PM Just_cruizin.
It is important to note, that after you have obtained approval from QT, as Bruce said, they will inspect the vehicle. If the vehicle is unroadworthy in any way, you will not get your mod plate. But you will get a defect notice :wink:
Post Posted: Tue Feb 08, 2011 6:53 pm
That's ok the car is stock except for 60mm lift and strut mount flip I just need to pull that out and replace 2 cv boots. This is the reason I wanted to do the bl while the car is stock. Thanksfor the info guys
Users browsing this forum: Google [Bot] and 350 guests
