It is currently Tue Oct 20, 2026 12:56 pm
Post Posted: Tue Feb 08, 2011 9:33 am
Hi its time to replace the clutch in my leafy it got a 1.6 efi with a sierra gearbox is there a heavy duty clutch i sholud run or is the standard clutch up to the task
Post Posted: Tue Feb 08, 2011 9:41 am
http://www.npcperformance.com.au/
If you want a h/d clutch that doesn't bust cable's & your left leg, talk to these guy's, I have fitted zillion's of their product's with no problem's...
Post Posted: Tue Feb 08, 2011 9:43 am
cheers so are there common problems with other heavy duty clutches i just thought i want it to last as long as possible
Post Posted: Tue Feb 08, 2011 9:46 am
What's there pricing like stekky
Post Posted: Tue Feb 08, 2011 9:48 am
Yep, I have only seen one out of the box h/d kit that work's & they don't make em for Suzuki's & have no intention of doing so..
Make sure you tell the guy's there what you will be doing with the car, if you bullshit them ( not saying you would) & say it's a 600hp comp truck, you will end up with a clutch that has stupid amount's of clamping pressure & will be unforgiving on road..
Post Posted: Tue Feb 08, 2011 10:01 am
pretty sure it has 108 horsepower haha
Post Posted: Tue Feb 08, 2011 10:04 am
I have used Exedy clutches with good reults. PBR have always crapped themselves in a seriously short timeframe. However the Exedy HD clutch in the ute was great at the start but turned into a complete pig by the end. Cable snapper :evil:
Post Posted: Tue Feb 08, 2011 10:05 am
do the standard sierra clutch handel the 1.6efi ok? they are cheep
Post Posted: Tue Feb 08, 2011 10:07 am
A standard Exedy will. No 6000rpm clutch drops and you will be fine. 8)
it is a daily driver first of all an a weekend warrier second
Post Posted: Tue Feb 08, 2011 10:13 am
i think i would break dropping the clutch at 6000 rpm
Post Posted: Tue Feb 08, 2011 10:17 am
Yep. I've done more than a few abusive launches in the ute with the 1.6 16v, and now my rear axles are suffering the consequences.... Chromo's on the way :roll:
Users browsing this forum: No registered users and 217 guests
