| Clutch sierra http://auszookers.com/forum/viewtopic.php?f=5&t=18945 |
| Author: | stiky [ Tue Feb 08, 2011 9:33 am ] |
| Post subject: | Clutch sierra |
Hi its time to replace the clutch in my leafy it got a 1.6 efi with a sierra gearbox is there a heavy duty clutch i sholud run or is the standard clutch up to the task |
| Author: | steak_knife [ Tue Feb 08, 2011 9:41 am ] |
| Post subject: | Re: Clutch sierra |
http://www.npcperformance.com.au/ If you want a h/d clutch that doesn't bust cable's & your left leg, talk to these guy's, I have fitted zillion's of their product's with no problem's... |
| Author: | stiky [ Tue Feb 08, 2011 9:43 am ] |
cheers so are there common problems with other heavy duty clutches i just thought i want it to last as long as possible |
| Author: | 89_tintop [ Tue Feb 08, 2011 9:46 am ] |
What's there pricing like stekky |
| Author: | steak_knife [ Tue Feb 08, 2011 9:48 am ] |
stiky wrote: cheers so are there common problems with other heavy duty clutches i just thought i want it to last as long as possible steak_knife wrote: http://www.npcperformance.com.au/
If you want a h/d clutch that doesn't bust cable's & your left leg, talk to these guy's, I have fitted zillion's of their product's with no problem's... Yep, I have only seen one out of the box h/d kit that work's & they don't make em for Suzuki's & have no intention of doing so.. Make sure you tell the guy's there what you will be doing with the car, if you bullshit them ( not saying you would) & say it's a 600hp comp truck, you will end up with a clutch that has stupid amount's of clamping pressure & will be unforgiving on road.. |
| Author: | stiky [ Tue Feb 08, 2011 10:01 am ] |
pretty sure it has 108 horsepower haha |
| Author: | Fatzook [ Tue Feb 08, 2011 10:04 am ] |
I have used Exedy clutches with good reults. PBR have always crapped themselves in a seriously short timeframe. However the Exedy HD clutch in the ute was great at the start but turned into a complete pig by the end. Cable snapper |
| Author: | stiky [ Tue Feb 08, 2011 10:05 am ] |
do the standard sierra clutch handel the 1.6efi ok? they are cheep |
| Author: | Fatzook [ Tue Feb 08, 2011 10:07 am ] |
stiky wrote: do the standard sierra clutch handel the 1.6efi ok? they are cheep
A standard Exedy will. No 6000rpm clutch drops and you will be fine. |
| Author: | stiky [ Tue Feb 08, 2011 10:07 am ] |
it is a daily driver first of all an a weekend warrier second |
| Author: | stiky [ Tue Feb 08, 2011 10:13 am ] |
i think i would break dropping the clutch at 6000 rpm |
| Author: | Fatzook [ Tue Feb 08, 2011 10:17 am ] |
stiky wrote: i think i would break dropping the clutch at 6000 rpm
Yep. I've done more than a few abusive launches in the ute with the 1.6 16v, and now my rear axles are suffering the consequences.... Chromo's on the way |
