It is currently Tue Oct 20, 2026 1:50 pm
Post Posted: Mon Feb 14, 2011 10:32 pm
Whats the best way to remove the old sill panel, so you get a nice tidy flat surface to mount the checkerplate?
91Sierra; 2in lift; 2inBL; 6.5s; 31muds;
Post Posted: Mon Feb 14, 2011 10:41 pm
You can use a special drill bit used for spot welds. It will make no holes in the panel if used properly or you can do it a bit rougher and use a grinder. If you searched you would find a few threads about this already.
Vehicle: 91 sierra, g16b,lift,30's
Post Posted: Mon Feb 14, 2011 11:03 pm
Drill out spot welds, grind/smooth surface of dags. Remove rust then use a zinc primer. Then predrill plate for rivets glue plate with sikaflex then rivet it on. Then seal all edges .
Post Posted: Mon Feb 14, 2011 11:15 pm
i learnt a tip from 2stroker where you dont seal the bottom edge, just incas moisture gets in through the top it can get out through the bottom, but will still stop any mud or anything getting it. good to try it
Post Posted: Mon Feb 14, 2011 11:24 pm
Yeh I meant to say not bottom edge, most bottom edges will be to fucked to seal anyway
Vehicle: 07 vvt jimny
Post Posted: Mon Feb 14, 2011 11:53 pm
get some rivnuts then u can remove them at anytime for cleaning/ rustproofing lol and just use a foam tape seal around the edges for a bit of security
sorry CHOP :P
Jimny's Are taking Over
Post Posted: Tue Feb 15, 2011 12:15 am
Cable ties?
helloo
Post Posted: Tue Feb 15, 2011 2:25 am
Thanks guys. One more job to tick off the list. Only 999 more to go. lol. Front bar next.
Post Posted: Tue Feb 15, 2011 7:16 am
Bingo, you will still go all the way through from time to time, but it's a shit load less messy then a normal drill of a grinder..
Post Posted: Tue Feb 15, 2011 7:51 am
Yeah thank 2stroker for that, he told me that:)
Users browsing this forum: No registered users and 249 guests
