It is currently Fri Oct 16, 2026 7:31 am
Vehicle: Yamaha scooter, 50cc
Post Posted: Wed Feb 09, 2011 5:12 am
After putting a body lift in the Sierra, I've noticed that the flexible tubing between the airbox and the carby is at a pretty severe angle, and the tubing has flattened out a bit. I'm assuming that this will be restricting airflow quite a bit.
How has everyone else sorted out this problem?
Post Posted: Wed Feb 09, 2011 5:24 am
last thread about this the common fix was a piece of tube the diameter of the top of the carby and same thickness as the bodylift between the carb and hat, with a longer bolt on there to hold it down :)
Post Posted: Wed Feb 09, 2011 9:40 am
Cheers Royce, that was pretty much what we came up with, but didn't measure to see if there will be any clearance issues between the hat and bonnet, does anyone know if there will be?
Post Posted: Wed Feb 09, 2011 10:09 am
bodylift means your bonnet is further away from your engine now by the same amount you are spacing it up :wink:
Post Posted: Wed Feb 09, 2011 10:41 am
:oops: :oops: :oops: Somebody just slap me
Post Posted: Thu Feb 10, 2011 11:20 am
I have Lifted it 2inches of body will i be affected?
Users browsing this forum: No registered users and 153 guests
