It is currently Wed Oct 14, 2026 8:23 am
Post Posted: Sun Feb 13, 2011 12:15 am
just wondering if u have to pull the transfer apart to change the front output bearing on a 1.3 transfer
Post Posted: Sun Feb 13, 2011 12:28 am
nope i rekon you can do it :D
Post Posted: Sun Feb 13, 2011 10:12 am
No the front output can be removed without pulling the case apart - if you were keen, it could probably even be done with the transfer still in the car.
However, why do you say the bearing needs replacing? If it's due to play, bear in mind it might be the tiny needle bearing inside the end of the transfer mainshaft that supports the front output.
It's pretty fiddly to get out. Still no need to pull the transfer apart, but I bet it's the culprit, and you'll need some tricky tools to get it out.
Last time I pulled one I made a puller out of some cut down allen keys welded together. They really are a PITA to get out.
Post Posted: Sun Feb 13, 2011 4:58 pm
i used a cold chisel (really narrow and sharp) split it on each side, and then tapped the new bearing in..... and not allot of bearing rebuild kit's come with them..... weaves sells em tho... :D
Users browsing this forum: No registered users and 324 guests
