It is currently Wed Oct 21, 2026 11:47 pm
Post Posted: Fri Feb 18, 2011 10:47 am
Does anyone know if a throttle body off a 2.5 or 2.7 will bolt up to a 2 litre and if they are bigger
Coming from when I owned a crumpledore bolting a 5 litre throttle body onto a 3.8 litre was a good power up
And was wondering if this would work in the same way for the h20a
What are your thoughts.
Post Posted: Fri Feb 18, 2011 10:54 am
May be bigger but without more fuel I fail to see any advantage :?
Post Posted: Fri Feb 18, 2011 11:04 am
Better air flow and with a decent exhaust should get rid of its asthma?
Post Posted: Fri Feb 18, 2011 11:06 am
x2 it may trick the ecu into giving more fuel, but how will the manifold flow to suit? Are the 2.7 manifolds larger?
Post Posted: Fri Feb 18, 2011 11:56 am
What do these engines run? MAF or MAP? Either which way the stock ECU can account for a moderate change in air flow characteristics as it uses either of the sensors to calculate overall ingested air.
Lil Foot!
Post Posted: Fri Feb 18, 2011 9:20 pm
Map..
I'm sure it could be made to fit, but, the H20's intake is far to small & run's different sensor's, get a 2.5 or 2.7 from the wrecker's or the like, you'll be snapping axle's with the rest off em..
H20 ecu I'm told can run a 2.5, BUT you have to run the lil H20 intake for the sensor's, defeating the purpose of the upgrade, so, H25 & ecu would give you more than enough power..
Post Posted: Fri Feb 18, 2011 9:29 pm
why?
the airflow meter determins that not the throttle body.
more likely it could lower your airflow velocity at low revs and give less power down low
Post Posted: Fri Feb 18, 2011 9:32 pm
why?
That's right, it's built into the throttle body..
Post Posted: Fri Feb 18, 2011 10:32 pm
I'd love a 2.5 litre but can't justify it when my engine has nothing wrong I was just after a cheaper option to power it
I understand what you guys are saying I'll
Just have to wait until my engine let's go it's got pretty low klms so it will be a while lol
Is there any other cheaper options to get a few more ponies ?
Post Posted: Fri Feb 18, 2011 10:42 pm
NOS or you could try one of those ebay "chips" or electric "superchargers"
Post Posted: Fri Feb 18, 2011 10:45 pm
Or premium ULP.... :lol:
Post Posted: Fri Feb 18, 2011 10:50 pm
Already use premium
So I guess that answers my question thanks for the info
Users browsing this forum: Google [Bot] and 120 guests
