It is currently Thu Oct 29, 2026 1:02 pm
Post Posted: Sun Feb 20, 2011 10:08 am
1992 suzuki sierra 2 inch lift, putting 2 inch extended shackles in on the week end................. will i need extended brakelines?....and if i do are vitara lines the same but longer??...... oh an is it advisble to shorten ur bump stops .,, or get some smaller ones?
Post Posted: Sun Feb 20, 2011 10:09 am
taa for any advice
Vehicle: Daisy
Post Posted: Sun Feb 20, 2011 10:13 am
All I know is that I have a 1990 with 2" spring lift, 2" body lift (which doesn't affect brake lines) and whoever put it in didn't extend the lines. If I jack the thing up and chock the chassis, the diff hangs down on the brake line so uh yeh, extended ftw!
Post Posted: Sun Feb 20, 2011 10:16 am
50mm suspension with 50mm hangers will give a total 75mm lift front will prob be ok possibly will require rears extending or bend brackets for the rear hose to destress hose at full drop.
Every zuk seems to be different depending of flex of springs.
Cutting or shorter bump stops are a bad idea. with that sort of lift you will have longer shocks make your stops any shorter and you run the risk of damaging your shocks under compression
Suzuki is my way of life.
Vehicle: 2018 DMAX
Post Posted: Sun Feb 20, 2011 10:25 am
Depends on your flex in the end.. This was mine with 2inch EFS comfort minus a leaf and 2inch shackels.. The brake line was all sorts of bad. My back didnt flex anywhere near enough to be an issue at this point tho.
Flex it up and check it...
Post Posted: Sun Feb 20, 2011 7:48 pm
so.....umm...... are vitara lines longer an can i use em???
Post Posted: Sun Feb 20, 2011 10:03 pm
vitara ones are too long, yes they will fit.
i use hyundai excell lines they are a great length
Post Posted: Sun Feb 20, 2011 11:11 pm
I use stock one with modified brackets 8)
Works well with my RUF
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Sun Feb 20, 2011 11:12 pm
lol, too much work in that dan :)
mine cost me ... well free from the wreckers lol
Post Posted: Sun Feb 20, 2011 11:13 pm
Bah a PhD is too much work compared to moving some steel brackets around :P
Lil Foot!
Post Posted: Sun Feb 20, 2011 11:15 pm
guess thats why i never did a PHD then hehe
Post Posted: Sun Feb 20, 2011 11:18 pm
Atleast you have an excuse.
I didn't do a PHD cos I'm too dumb. Thats clear, as I beat steel into funny shapes for a living :lol:
Post Posted: Sun Feb 20, 2011 11:19 pm
my sister did a doctorate in microbiology so brains is in the family, im just too lazy :helloo:
Post Posted: Sun Feb 20, 2011 11:24 pm
tanshi wrote:
lol, too much work in that dan Smile
:thefinger:
Lil Foot!
Users browsing this forum: No registered users and 353 guests
