http://auszookers.com/forum/
RUF setup, redrill, OME allround
http://auszookers.com/forum/viewtopic.php?f=5&t=19335
Author:  experament-u2 [ Mon Feb 21, 2011 6:38 am ]
Post subject:  RUF setup, redrill, OME allround
so i am looking at doing a RUF in my sierra in the near future (92, WT) i am looking at redrilling the rear mount and extended shackels atm as i feel my wielding skills are not upto scratch to do an extention.
i am thinking 40mm lifted OME in the rear, and front because they are similar lengths eye to eye as stock rears, (from what i have found searching).
i am gessing with the extended shackle up front it will lift the front spring a little making it higher than the back. would putting an extended shackle in the back to level out the lift work? (if i can get the angle correct)
or will stock rears with extended shacked up front be better, as they give basicly the same lift as a set of OMEs in the rear meaning leaving the rear alone, and a cheap front suspention setup
cheers
