| H20a v6 cutting out http://auszookers.com/forum/viewtopic.php?f=5&t=19601 |
| Author: | inbits [ Tue Mar 01, 2011 8:33 am ] |
| Post subject: | H20a v6 cutting out |
Ok so I have had a problem with my vitara v6 manual
When cruising along in any gear at any speed and not under load the engine surges like it's cutting in and out. It is most noticeable when the engine rpm is between 2700-3300 rpm Also when the car has sat idle(not running) for 10 minutes give or take and you start it up and drive off it surges really badly like the engine cuts out completely for 2-3 secs then cuts in ( makes it look like I'm a piss poor driver This problem is amplified when in low range and makes it hard to just cruise along It feels like I'm accelerating and decelerating constantly but it's not me it's the car Does anyone know what would cause this? Sorry for the long post |
| Author: | joeblow [ Tue Mar 01, 2011 9:42 am ] |
| Post subject: | Re: H20a v6 cutting out |
coil pack snouts shorting out on the rocker cover?......quite common. |
| Author: | inbits [ Tue Mar 01, 2011 9:47 am ] |
I'll pull the covers of te coil packs and take a look That would cause a slight misfire swell hey? I'll report my findings Cheers |
| Author: | atari4x4 [ Tue Mar 01, 2011 9:52 am ] |
yeah, it will be a missfire as the spark jumps. you'll need to pull the coil covers off each bank & remove each coil pack & probe, if it's been doing it for a bit you should be able to see the white tracking marks left from the spark jump. |
| Author: | inbits [ Tue Mar 01, 2011 6:47 pm ] |
Ok if I get time I'll do that tonight it's been doing it for ages and slowly getting worse |
| Author: | inbits [ Wed Mar 02, 2011 6:52 am ] |
Ok so I pulled the left bank apart and there is alot of white looking corrosion down inside the tubes is this from them tracking? I'm going to check the right bank tomorrow when I've got the tools to clean it up properly. Is there anything I can spray it all with to stop this or do the coil packs need replacing? I also managed to crack one of the plugs on the coil pack not badly and it is still connected and not causing a problem but how much are they to buy? And does anyone know the part number for spark plugs to suit the h20a |
