It is currently Fri Nov 06, 2026 12:31 am
Vehicle: SWB GV
Post Posted: Thu Mar 03, 2011 4:33 am
hey guys,
sorry if this has been asked be4, but my search only bought up problems with diffs not disengaging...
On the freeway today in my white Jimny, the diff light started flashing (as it does whilst it's trying to engage), then would randomly turn off. the wires are farked and it's never really endaged properly but I've not worried about it coz I use my other car to fourby.
Anyhoo, it did it a few more times, then I could FEEL (and hear) it actually trying engage. Is there an easy way to disconnect it coz I recon maybe the heat on the exposed wires is messing it up?
I was thinking of just pulling out the fuse, but is that just for the light in the dash? Where is the actual connection so I can stop the bastard from locking in - especially when I'm fanging up a highway.
Shanks :)
Post Posted: Thu Mar 03, 2011 4:37 am
can you follow the wires that are burnt and see if they end in a plug somewhere? if there is a plug upstream (like on the bit fat loom on the firewall) side, unplugging that should kill it
the fuse would be for the whole system as well, I am suprised it hasnt blown yet
Post Posted: Thu Mar 03, 2011 4:39 am
Un plug the buggered wire's from the transfer, & just to be sure, there is a lil vaccume switch under the bonnet, unplug that to..
Oh, & book in at Stekky's Suzuki love shop.. :stekky:
Vehicle: SWB GV
cool thanks, i'll try that once it's not so bloody hot under it.
otherwise the fuse it out!
Beer Fairy
Post Posted: Thu Mar 03, 2011 5:17 am
Maby ur Jimny is asking to go 4wding :P
Post Posted: Thu Mar 03, 2011 8:07 am
u should do a crazy motor swap in it and keep it rwd take it to burn out comps hahhaha
Post Posted: Thu Mar 03, 2011 9:07 am
Or not........
Could also be the front hub's trying to lock in, from a short in the transfer harness.....
Vehicle: SWB GV
Post Posted: Thu Mar 03, 2011 10:02 am
i dunno what it is, but it's freaking me out.
i checked out a pic i took of it a few weeks ago and can just see the connection, so I'm just gonna disconnect the fucker.
then take it to Stekky! :)
Beer Fairy
Post Posted: Thu Mar 03, 2011 10:03 am
:helloo:
Post Posted: Thu Mar 03, 2011 2:38 pm
Too much lectrics in them things.... :helloo:
:stekky:
Vehicle: SWB GV
Post Posted: Thu Mar 03, 2011 11:10 pm
i know right?? what's wrong with a second blooody gear stick!!
Could be worse, you could be my dad who has made a meal of the Fiat... it's stuck
Post Posted: Fri Mar 04, 2011 12:20 pm
What, no winch? 8O
Vehicle: 91 swb vit 5"lift 31's.
Post Posted: Tue Mar 15, 2011 9:48 am
^^^ FLEXIN... haha nice pic! ^^^ :D
Post Posted: Tue Mar 15, 2011 10:01 am
Oh year, this is fixed, the 4wd light switch had at one stage rubbed against the exhaust, causing the outer sheath to melt, then once water got in the 2 wire's would make contact, the control module then thinks 4wd is selected & try's to engage the front hub's..
replace burnt section & conduct, re-routing out of the exhaust's way.. :D
& Liz made lunch... :P
& poked hole's in her car... 8O
Post Posted: Tue Mar 15, 2011 10:03 am
what part of the car??
Post Posted: Tue Mar 15, 2011 10:05 am
Body mount's, chassis side...... 8O
Post Posted: Tue Mar 15, 2011 9:08 pm
Hey Zookliz when it happens does it make like a grinding whiring noise at the source? Or is it simply the 4WD light coming on?
Mitch.
Vehicle: SWB GV
Post Posted: Tue Mar 15, 2011 9:39 pm
The light would come on, but then I'd feel the freaking thing trying to engage through the floor.
I can't hear what it sounds like over the horrible noise the engine makes :oops:
but it definately was trying to 'clunk' in.
all good now though, once I got the water out of it, and steaky replaced the wiring it's fine.
under my car is a depressing place to be
Post Posted: Wed Mar 16, 2011 12:29 am
Oh okay, when i get bumps at speed my hubs or something start to make that clunking grinding noise.
The only way i can stop it is to pull over and either come to a complete stop or jam it in 4WD at 20km/h.
Was that the same thing?
Mitch.
Vehicle: SWB GV
Post Posted: Wed Mar 16, 2011 12:59 am
no, but mine does that too - if i hit a speen bump too fast (as i usually do) it sets them off!
annoying, isn't it!
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Wed Mar 16, 2011 1:18 am
you can fit some manual hubs or vitara solid flanges, disconnect and block off the vacuum lines.
Post Posted: Wed Mar 16, 2011 5:55 am
:lol: It's frucked.... 8O
Vehicle: SWB GV
Post Posted: Wed Mar 16, 2011 5:57 am
and little things crawl on my and bite
Post Posted: Wed Mar 16, 2011 6:04 am
I sprayed for that, not sure if they were living in your car or the shed, shed crab's are common in this area I'm told.. :?
Vehicle: SWB GV
Post Posted: Wed Mar 16, 2011 9:29 am
i was refering 2 u actually....
haha
Post Posted: Wed Mar 16, 2011 9:35 am
:lol: :lol:
Oh tar!!!! :lol: :lol:
Vehicle: WT Tinny, NT lwb, 1L lwb
Post Posted: Wed Mar 16, 2011 10:53 am
I saw a porn that started out just like this once.......
JrZook - Mine only hangs 2.5".
 Profile WWW ICQ YIM
Users browsing this forum: No registered users and 141 guests
