It is currently Fri Oct 09, 2026 4:32 am
Post Posted: Mon Apr 21, 2008 4:34 pm
i posted this somewhere else but it aint a strange noise so....
2nd gear using the engine braking it sounds like it is backfiring, does this mean it's runing too rich on fuel or not getting enough or is there somethin else?
all knowledge and and unworldly ideas appreciated.
Grizz
Vitara gone, tis no more. replaced by a 98 XH Falc
Post Posted: Mon Apr 21, 2008 4:41 pm
too rich
retarded timing
(most likely) hole in exhaust
Post Posted: Mon Apr 21, 2008 5:06 pm
Sierra or Vit? The spring loaded joing between the manifold and the exhaust pipe can let air in. I've had that problem before a couple of times.
Post Posted: Mon Apr 21, 2008 5:25 pm
come to think of it mine is stuffed there with bits of bark jammed in it
I have aircon so keep the windows up, no noise :)
Post Posted: Mon Apr 21, 2008 5:32 pm
Windows up, air con on and stereo turned up loud.... problem solved!
Seriously though, probably not worth worrying about. If it gets worse then maybe start looking for a possible problem. If it starts spitting flames then get a flame arrester for the tip. If the exhaust falls off then there was probably a weakness there somewhere.
Post Posted: Mon Apr 21, 2008 8:17 pm
royce it's not retarded timing my car IS Retarded
hole in zorst aint it either the noise is at the arse of the car also i looked for holes (not a good idea after going for a drive cause it is hot :windowface: )
Post Posted: Mon Apr 21, 2008 8:21 pm
did you measure the timing while going down hill?
jam a wet rag in the tailpipe at idle will show up any holes a lot easier
Post Posted: Mon Apr 21, 2008 10:04 pm
Mine constantly pops/backfires every few seconds when engine braking in any gear.
92 WT softback ute, twin lockrights, 3.9 diffs, S1
Post Posted: Mon Apr 21, 2008 10:53 pm
sounds like a plan royce could be holes on top (me stupid)
how do ya mesure timeing going down a hill?
Post Posted: Mon Apr 21, 2008 11:10 pm
you cant, hence you cant discount it
unplug and block off the vacuum hoses to the dizzy, see what happens
Post Posted: Tue Apr 22, 2008 2:09 am
Most Vitara's exhaust manifold's are cracked between the 3 & 4 outlets.. This will cause the problem you are having.. Get a set of extractors for it and you'll be much happier. ;)
Thanks,
Chris
http://www.nbs4x4club.com
Post Posted: Tue Apr 22, 2008 2:30 am
i gonna get a full zorst system fitted when i get the money
Post Posted: Tue Oct 21, 2008 9:07 pm
how do you stop this consistent back firing my new zook has this issue
only when changing down gears when i put the accelrator down again it back fires :( did not do it on the test drive only after about 40km of driving dammit
Post Posted: Wed Oct 22, 2008 2:11 am
Check all gaskets on ya zorst that was the prob with mine last time, now it backfires/burbles cause of the 2.5inch straight through :twisted:
lesspostingmorewheeling
Post Posted: Wed Oct 22, 2008 2:31 am
isn't popping/gurgling also caused by lack of back pressure?
Post Posted: Wed Oct 22, 2008 4:14 am
Yes Mike that's right, often when you fit a larger free flowing exhaust the reduction in exhaust velocity and backpressure will cause poping and gurgling sounds from the exhaust during deceleration.
Post Posted: Wed Oct 22, 2008 11:54 pm
i have standard zorst up to the start after the cat if ya know what i mean
Users browsing this forum: Google [Bot] and 234 guests
