| need help with power steering http://auszookers.com/forum/viewtopic.php?f=5&t=20054 |
| Author: | zookbox [ Wed Mar 16, 2011 1:13 am ] |
| Post subject: | need help with power steering |
I have a zook running on a calmini 5 inch lift iv just installed power steering from a vitara and im not sure what to do. If i get a drop pitman arm will this be enough for the lift or do i have to go hi steer.????? help me please
| Author: | want33s [ Wed Mar 16, 2011 1:50 am ] |
| Post subject: | Re: need help with power steering |
5" lift |
| Author: | zookbox [ Wed Mar 16, 2011 2:16 am ] |
yea |
| Author: | Damo [ Wed Mar 16, 2011 2:47 am ] |
zookbox wrote: I have a zook running on a calmini 5 inch lift iv just installed power steering from a vitara and im not sure what to do. If i get a drop pitman arm will this be enough for the lift or do i have to go hi steer.?????
help me please ![]() With 5" lift i'm guessing high steer. Have a look at the angle between your drag link and tie rod, those are supposed to be as close to parallel as possible. Now look at your pitman arm and see how much drop you need to get those arms parallel or close to. If you need any more the 2" then high steer is the better solution. |
| Author: | zookbox [ Wed Mar 16, 2011 5:16 am ] |
cheers mate thanks for the help hey can you help us a little how hi steer works sorry im new to zooks |
| Author: | ajsr [ Wed Mar 16, 2011 5:17 am ] |
is the calmini 5" lift spoa? I thought it was 3" springs and shacle reversal or some gay shit like that. if it is you wont be able to high steer I dont think. |
| Author: | royce [ Wed Mar 16, 2011 5:19 am ] |
big bumpstop extensions on em do tey make a drop pitman arm to fit a vit box thats drops as much as a sierra drop pitman arm? if so jsut stick that on, wont be any worse than it was |
| Author: | appsie [ Wed Mar 16, 2011 5:23 am ] |
arent the drop pitman arms longer too?and can cause dramas that way then aswell. put some pics up of the car,lift and steering? |
| Author: | steak_knife [ Wed Mar 16, 2011 6:22 am ] |
royce wrote: big bumpstop extensions on em
do tey make a drop pitman arm to fit a vit box thats drops as much as a sierra drop pitman arm? if so jsut stick that on, wont be any worse than it was Yep, I have one in the shed.. Unless your running stupid lift, the thing interferes with the r/h spring on full compression l/h down.. |
| Author: | zookbox [ Wed Mar 16, 2011 8:53 am ] |
i will post them up in a couple of days when i get some pics i got told its a 5 inch lift but its still sprung under so im not sure.. |
| Author: | royce [ Wed Mar 16, 2011 9:12 am ] |
wont hit on a calamari 5" cause its got big extensions and is shackle reverse so swings the other way |
| Author: | steak_knife [ Wed Mar 16, 2011 9:21 am ] |
royce wrote: wont hit on a calamari 5" cause its got big extensions and is shackle reverse so swings the other way
Oh yes, the reverse shackle thingy... |
| Author: | zookbox [ Thu Mar 17, 2011 2:50 am ] |
any ideas what lift it is |
| Author: | zukmeista [ Thu Mar 17, 2011 4:33 am ] |
Yup, that's calmini gear
| Author: | zookbox [ Thu Mar 17, 2011 10:24 am ] |
yea sure is. any ideas on what size lift it is????? |
| Author: | Red89 [ Thu Mar 17, 2011 10:28 am ] |
Looks like their 5 inch which consists of the 3 inch springs and 2 inch shackle reversal. |
