It is currently Tue Jun 23, 2026 2:21 pm
Post Posted: Wed Mar 16, 2011 1:13 am
I have a zook running on a calmini 5 inch lift iv just installed power steering from a vitara and im not sure what to do. If i get a drop pitman arm will this be enough for the lift or do i have to go hi steer.?????
help me please :please:
Post Posted: Wed Mar 16, 2011 1:50 am
5" lift 8O :blink: 8O
Post Posted: Wed Mar 16, 2011 2:16 am
yea
Post Posted: Wed Mar 16, 2011 2:47 am
With 5" lift i'm guessing high steer.
Have a look at the angle between your drag link and tie rod, those are supposed to be as close to parallel as possible. Now look at your pitman arm and see how much drop you need to get those arms parallel or close to.
If you need any more the 2" then high steer is the better solution.
Post Posted: Wed Mar 16, 2011 5:16 am
cheers mate thanks for the help hey can you help us a little how hi steer works sorry im new to zooks
Post Posted: Wed Mar 16, 2011 5:17 am
is the calmini 5" lift spoa?
I thought it was 3" springs and shacle reversal or some gay shit like that.
if it is you wont be able to high steer I dont think.
Post Posted: Wed Mar 16, 2011 5:19 am
big bumpstop extensions on em :)
do tey make a drop pitman arm to fit a vit box thats drops as much as a sierra drop pitman arm? if so jsut stick that on, wont be any worse than it was
Post Posted: Wed Mar 16, 2011 5:23 am
arent the drop pitman arms longer too?and can cause dramas that way then aswell.
put some pics up of the car,lift and steering?
Post Posted: Wed Mar 16, 2011 6:22 am
Yep, I have one in the shed..
Unless your running stupid lift, the thing interferes with the r/h spring on full compression l/h down..
Post Posted: Wed Mar 16, 2011 8:53 am
i will post them up in a couple of days when i get some pics i got told its a 5 inch lift but its still sprung under so im not sure..
Post Posted: Wed Mar 16, 2011 9:12 am
wont hit on a calamari 5" cause its got big extensions and is shackle reverse so swings the other way
Post Posted: Wed Mar 16, 2011 9:21 am
Oh yes, the reverse shackle thingy... :roll:
Post Posted: Thu Mar 17, 2011 2:50 am
any ideas what lift it is
Post Posted: Thu Mar 17, 2011 4:33 am
Yup, that's calmini gear :helloo:
Post Posted: Thu Mar 17, 2011 10:24 am
yea sure is. any ideas on what size lift it is?????
Post Posted: Thu Mar 17, 2011 10:28 am
Looks like their 5 inch which consists of the 3 inch springs and 2 inch shackle reversal.
Users browsing this forum: Google [Bot] and 78 guests
