It is currently Tue Jun 23, 2026 5:40 am
Post Posted: Thu Mar 17, 2011 7:05 pm
Hi guys I am just wondering what power steering belt tensioner idler you guys with PS are running? Mine is not large enough to tension belt properly and it squeals when adjusted to max position.
probly need tension idler to be 10mm bigger in Dia to enable correct belt tension.
David
Zuki
Suzuki Sierra 1990 Hardtop
Now just drive i
Post Posted: Thu Mar 17, 2011 7:09 pm
OR come down a belt size.
Bill
*JIMNY*
'99 G13BB, Auto, White.
Post Posted: Thu Mar 17, 2011 7:16 pm
Bill
Hi Bill,
The next size down belt is to small; can't get it on pully's!! Tried that.
David
Zuki
Now just drive i
Post Posted: Thu Mar 17, 2011 7:37 pm
That's odd as most belts are in increments of 15mm. The belt tensioner will take up alot more than that, atleast the Vitara one does.
Post Posted: Thu Mar 17, 2011 7:39 pm
Cheers, I should of mentioned I'm running Jimny PS including the bracket the bolts to engine. It is the cast one not fabricated one!
Also belt is multi grooved type!
Zuki
Now just drive i
Post Posted: Thu Mar 17, 2011 8:01 pm
Yes multigroove belts come in increments of 15mm. Surely the next size down and the tension pulley at it's lowest will go on?
Vehicle: Nissan
Post Posted: Thu Mar 17, 2011 8:58 pm
get the next size down and turn the engine over making the belt streach on
Pearce-toff Racing
Post Posted: Thu Mar 17, 2011 9:24 pm
It's been a while since I installed it, but I'm pretty sure I tried the next size down and couldn't get it remotely close to going on..................without damaging something!!
Zuki
Now just drive i
Post Posted: Thu Mar 17, 2011 9:47 pm
What size belt do you have now?
Are you just trying your suppliers next belt down. or are you ordering in the next size down that they make? sometimes they have as little as 5mm between sized and with multi rib belts, 5 mm can make all the difference.
If your not sure whats available, let me know the size you have on now ie 4pk0990 or whateve, and i'll look on gates and dayco and see what sizes they stock/make for you, so you know what options you have
weaves
Post Posted: Sat Mar 19, 2011 12:20 am
To find the correct belt would be the way to go.... as a last resort you could have a sleeve made to increase the diameter of the belt tensioner.
Bill
*JIMNY*
Post Posted: Sat Mar 19, 2011 2:34 am
if you actually go to a larger belt supplier, you will generally be able to find belts in 5mm increments
Users browsing this forum: No registered users and 108 guests
