It is currently Mon Sep 21, 2026 4:24 am
Post Posted: Fri Mar 18, 2011 9:30 pm
Hi guys,
looking for info one where you have purchased your EFI fuel system parts.
I'm after a low pressure lift pump, small surge tank ( 800ml- 1ltre) and the high pressure delivery pump.
Its for a vit with a g16b in it, currently running an efi tank with internal pump, but have a clean carby tank that I want to put in it, as the EFI tank has a significant amount of rust internally.
anyone got suggestions on where to purchase?
thanks,
Chris
Post Posted: Fri Mar 18, 2011 9:37 pm
I got a facet lift pump, 2 litre polished alloy surge tank and a 2nd hand Bosch 044 all off Ebay for $200 delivered.
Post Posted: Fri Mar 18, 2011 9:41 pm
Pumps from repco, they have a Fuel Miser pick up pump in either a rotary and a clacker type, ask to look at the book and you will see a few different shapes and mounting designs, for the high pressure again Fuel Miser brand VL commodore which comes with a chassis mounting bracket. Surge tanks from Extreme at Northgate or even Autobarn and some of the larger Supercheap stores have them.
Post Posted: Fri Mar 18, 2011 10:31 pm
i went carter then bosh 044
josh AKA Bazook
Post Posted: Sat Mar 19, 2011 12:08 am
Bosch 044 is VL commonwhore.
Post Posted: Sat Mar 19, 2011 12:21 am
sorry mate, it isnt.
vl pump a 070 and has barb ends and low pressure can handle 350hp.
044 has threaded fittings ether end, high pressure and mega flow. can support 750 hp.
Post Posted: Sat Mar 19, 2011 2:16 am
OK mine was listed as Bosch 044 / VL.... Just assumed the seller knew what it was... :? Works fine anyway.
Post Posted: Sat Mar 19, 2011 3:21 am
Yep. 070 is VL. 044 is bosch motorsports pump.
Post Posted: Sun Mar 20, 2011 2:20 am
thanks guys.
cheers,
Chris
Users browsing this forum: No registered users and 198 guests
