It is currently Fri Nov 06, 2026 6:18 am
Vehicle: stock yellow vit.
Post Posted: Sat Mar 19, 2011 6:50 am
hey guys im in the process of doing up a vitara its nearly at registration stage it has a lif and some guard chopping has been done i have put some 31x10.5 r15 tires on a 8 inch rim and flexed it up it dosent seem to hit anywhere just wondering how they would go with the stock gearing
its a 89SWB vitara
Post Posted: Sat Mar 19, 2011 6:58 am
yeah it slows the pickup down a fair bit but they still sit on 100 ok enough
Post Posted: Sat Mar 19, 2011 8:07 am
be careful off road :) theres a few lovely pictures of cracked up front diff's on here :)
Stocker
Post Posted: Sat Mar 19, 2011 9:49 am
what sise would you recommend then (stocker)
Post Posted: Sat Mar 19, 2011 11:20 am
31" tyres are fine. As mentioned, you will find the pick up on the lights alittle different. Unlocked front and rear i ran a standard front diff for about 2 years. Was fine. Ive also had someone with welded front never had a problem with his standard diff. But saying that it is easily the weakest point on a standard vit.
Just replace it with a steel one once it breaks.
Post Posted: Sat Mar 19, 2011 8:58 pm
Couldn't reccomend you a size, as i haven't upsized mine yet. i'm looking at running some 30 x 9.5" R15's i've been told they are a little less strenuous on the Front diff :)
Alot of the dudes on here run 31's fine, just seen a fair few broken front diffs too :)
Stocker
Post Posted: Sat Mar 19, 2011 9:29 pm
the front diff can break on any size tyre just depends what you drive ie terrain and how you drive
i broke mine on 29 inch tyres on rock just lifted a wheel and it came down not that heavy and bang front diff gone
but as said just go with the tyres you want and upgrade the diff when it goes
Post Posted: Sat Mar 19, 2011 9:34 pm
By gone you mean shattered :wink: What Tombutt said, depends what/how you drive. Do you have a steel housing in the front??
Post Posted: Sat Mar 19, 2011 9:40 pm
was that directed at me rushapoo?
Post Posted: Sat Mar 19, 2011 9:56 pm
:finger: :finger: :peaceout: pompoms pompoms :steamroller: :rambo: :windowface:
Post Posted: Mon Mar 21, 2011 12:01 am
I just found out that my mate on 33 and sc on his swb still runs alloy diff.
He has moded the mounts a bit but.
Post Posted: Mon Mar 21, 2011 12:07 am
^^ It's not necessarily the mounts that clap out. Tombutts diff exploded around the pinion. Is your mates a steel diff?? It's the fact the alloy housing is weak as piss and can fracture in a few places :wink:
Post Posted: Mon Mar 21, 2011 1:44 am
I snapped my third member on standard tyres around the pinion bearing they can last and they can also explode very easily depending on how and what you drive.
Get a steel one if you can find one for a reasonable price if not leave it and keep your fingers crossed
There is some good info here http://bbs.zuwharrie.com/content/topic, ... 0/all.html
There's a guy running 35's on standard alloy one
Post Posted: Wed May 04, 2011 6:01 am
we how do 31's go offroad?
what about rock crawling? wouldn't it be impossible with stock gearing?
Post Posted: Wed May 04, 2011 12:12 pm
Nup - most of us start looking at transfer gear options, but it's far from impossible on standards. Can mean a fair bit of clutch work if you're manual though.
Post Posted: Wed May 04, 2011 12:46 pm
i was out with him on the weekend and he was crawling fine. i dunno how much clutch he was using and i could hear it was revving alot lower than mine (on 215's) but he was managing it well
Post Posted: Sat Sep 03, 2011 2:48 am
instead on starting a new thread, thought i would just go with this one.
trying to put my 31's on, the front is fine except for the steering stops. but the rear im having issue with the bumper flare mount. does anyone have any info on what they did or has mine been bent towards the tire?? (was rear impacted b4 i bought it)
oh and rear bumpstops, is there anyway of doing it besides drilling a hole in the lower spring purch and fitting nut and bolt through block? (atari method)
cheers
Post Posted: Sat Sep 03, 2011 3:21 am
a small bumpstop extension can be fitted to the top, (ninjamoses style)but for the size that i required it caused the spring to hit the bumpstop during flex.
Post Posted: Sat Sep 03, 2011 4:01 am
oh ok, ill have to see what he did. do you think i would need 2" bump stops ext? my coils are only 50mm longer in standing length than std,
oh dw about the bumper thing, got the grinder out and cut the little tab off :D
Post Posted: Sat Sep 03, 2011 4:13 am
NFI, the only way to really find out is to flex it & check it. :P
Post Posted: Sun Sep 04, 2011 12:25 pm
yeah tru, oh and i dont know who told you that 5th is uter crap with 31's but honestly its not that bad. i drove 150km today (90kph-110kph), its a little slow but really not that noticable, revs are a bit lower and it doesnt have as much torque up hills but still good to drive non the less.
Post Posted: Sun Sep 04, 2011 12:28 pm
i never said anything about 5th being useless? :? you have to agree it's not what it used to be....
Post Posted: Sun Sep 04, 2011 12:38 pm
im sure i read something last nite, maybe it was that other atari bloke. you know the one? :wink:
yeah its not the best but its not bad. i would like to drive a stock vit again to see the difference. i havnt driven a stocky for 2 yrs, that was when mine was stock.
speedo is almost exactly 10% out. 90 is almost bang on 100. 45 being 50.
Post Posted: Sun Sep 04, 2011 12:53 pm
theres mention in that thread, that a kia front diff bolts straight in, and is steel....has anyone looked into this?
Go Hard, Trailer Home
Post Posted: Sun Sep 04, 2011 1:19 pm
yeah definately that other atari bloke... :oops: :thefinger:
say good bye to 5th gear & any sort of low range gearing....
http://auszookers.com/index.php?name=Fo ... t=5th+gear
10% loss of reduction is still pretty bad IMO. does it hold fifth without labouring it & will it still accelerate at 110kph?
Post Posted: Sun Sep 04, 2011 1:24 pm
ahaha told you! yeah it cruises really easily and yeah could go more but it was the first biggish drive with the tyres so didnt no how far i could get (fuel consumption wise) so didnt want to push it.
Users browsing this forum: No registered users and 102 guests
