| NT transfer into WT http://auszookers.com/forum/viewtopic.php?f=5&t=20232 |
| Author: | canberramav [ Tue Mar 22, 2011 1:17 am ] |
| Post subject: | NT transfer into WT |
Hey Can i use the NT transfer into a WT.? ie take the handbrake drum off and change the flanges over using parts from my blown WT transfer case? Will this make it the same as a WT transfer case? Cheers |
| Author: | JrZook [ Tue Mar 22, 2011 1:23 am ] |
| Post subject: | Re: NT transfer into WT |
Yes provided the nt case was a 1.3 case. |
| Author: | tanshi [ Tue Mar 22, 2011 1:24 am ] |
JrZook wrote: Yes provided the nt case was a 1.3 case.
or a one litre with 4x4 switch case. (though this would lower your gearing) |
| Author: | canberramav [ Tue Mar 22, 2011 1:45 am ] |
Thanks guys 6.5s are going into it. Just never mucked around with a NT case before. It is out of a 1.3. |
| Author: | shep [ Tue Mar 22, 2011 1:51 am ] |
you might have to grind out the case a bit more then a wt to fit the gears but the case is the same |
| Author: | zukmeista [ Tue Mar 22, 2011 4:21 am ] |
shep wrote: you might have to grind out the case a bit more then a wt to fit the gears but the case is the same
??? Please explain why? |
| Author: | neofitou [ Wed Mar 23, 2011 1:52 am ] |
nah, I hardly had to grind any off mine at all. mines a 1.3L NT. |
| Author: | Fatzook [ Wed Mar 23, 2011 2:02 am ] |
canberramav wrote: Thanks guys
6.5s are going into it. Just never mucked around with a NT case before. It is out of a 1.3. Let me know if you haven't seen them by friday |
