It is currently Mon Sep 21, 2026 2:54 am
Post Posted: Sun Mar 27, 2011 11:24 am
just a question to test the zook owner minds,
who knows the length of the front axles and cvs in a jimny, are the cvs the same as a wide track, cheers
Post Posted: Sun Mar 27, 2011 11:29 am
CV's are smaller than 1.3 WT sierra. Axles would be longer as Jim diff is wider.
Post Posted: Sun Mar 27, 2011 11:32 am
is it only the short side side that is longer or are both, looking to try get some decent axles and cvs for when these 1s decide to break
dodgy brothers mechanical
Post Posted: Sun Mar 27, 2011 11:57 am
Pretty sure its both. You are not a pioneer unfortunately. This has been researched already and proven to be unfruitful.
Contact Joe about some HD shafts.
Post Posted: Sun Mar 27, 2011 12:07 pm
yea some 1 said to check the widths agains a wide track, to see if i could just get to wt long axles and have 1 cut and resplined,
was also told that maurita? axles and cvs are the same jsut there 26 spline instead of wat the jimny has, think it was trail gear that told me that
Post Posted: Sun Mar 27, 2011 12:08 pm
Piranha off road do them for like 2k
Post Posted: Sun Mar 27, 2011 12:14 pm
i knosw a coily rear short side shaft is the same as an LJ50 rear shaft but its 26 spine :)
Post Posted: Mon Mar 28, 2011 12:21 am
Jimny axles are 40mm wider than Sierra WT stuff. The jimny also runs a 1 litre style cv that has a 19 spline input shaft, not 22 like Sierra gear. As far as I know (from what I have been told) the piranha axles are just an upgrade to 22 spline Sierra type.
Post Posted: Mon Mar 28, 2011 8:39 am
i couldn have a long shaft made and use chromoly cvs from a sierra, damn it
Post Posted: Mon Mar 28, 2011 9:23 am
You get the CV's and I can make the shafts.
Post Posted: Mon Mar 28, 2011 10:33 am
if i get chromoly cvs from a sierra u will make me chromoly axles, ok, how much
Users browsing this forum: Bing [Bot] and 190 guests
