http://auszookers.com/forum/
Hilux diff centres
http://auszookers.com/forum/viewtopic.php?f=5&t=20460
Author:  turbo_deo [ Tue Mar 29, 2011 7:34 am ]
Post subject:  Hilux diff centres
Okay so this is sort of a Suzuki question as I have lux diffs in my zook.
I have a welded front diff and an open rear centre, I have bought an air leaker and was wondering if someone could tell me if the front and rear centres are interchangeable, as I would prefer the air locker in the front rather than the back.
Thanks in advance for the help :helloo: :D
Author:  stocker [ Tue Mar 29, 2011 7:38 am ]
Post subject:  Re: Hilux diff centres
and you'd prefer the Welded diff in the rear???
Author:  turbo_deo [ Tue Mar 29, 2011 7:41 am ]
More than the front, will only be for a short while until I get another airlocker :D
Author:  stocker [ Tue Mar 29, 2011 8:01 am ]
i see...
i'd still put the thing in the back... at least your axles will thank you when you put the 2nd Locker in the front
Author:  want33s [ Tue Mar 29, 2011 8:10 am ]
Front and rear lux diffs are interchangeable....
Author:  turbo_deo [ Tue Mar 29, 2011 8:18 am ]
Cheers jas
Author:  shep [ Tue Mar 29, 2011 8:38 am ]
check this out
http://forum.darwin4x4.net/viewtopic.php?f=6&t=4834
he is also a AZ member
Author:  turbo_deo [ Tue Mar 29, 2011 8:47 am ]
Thanks shep I'll check that out after all the outgoings for the bills are paid and see how the funding is looking
Author:  want33s [ Tue Mar 29, 2011 9:25 am ]
I just bought a pair of ARB lockers in 4.88 centres (one a hi pinion) for $1500.... A mate bought just an ARB locker for $250..
They are around AND cheap if you look hard enough....
Author:  turbo_deo [ Tue Mar 29, 2011 9:40 am ]
Is there any advantage to a high pinion diff? I picked up my arb new in box for 800, I have been looking for a second cheap one
Author:  SierraDan [ Tue Mar 29, 2011 9:42 am ]
Where do you look for them?
Author:  turbo_deo [ Tue Mar 29, 2011 9:46 am ]
Other forums, i found mine by googling arb hilux locker :lol:
Author:  appsie [ Tue Mar 29, 2011 9:55 am ]
i believe in a hilux they most certainly are 8)
Author:  want33s [ Tue Mar 29, 2011 10:42 am ]
High pinion raises the tailshaft and gives a lot more ground/rock clearance....
80 series use hi pinion front standard....
Author:  joeblow [ Tue Mar 29, 2011 10:52 am ]
Hi pinion was designed so the gears use the stronger 'drive' side when placed in a front diff moving in the forwards direction. Placing one in the rear would mean you would be using the weaker 'coast' side when going forwards.
