It is currently Thu Oct 29, 2026 1:03 pm
Post Posted: Tue Mar 29, 2011 12:20 pm
so my brake lights have stopped working, globes are fine but i put a test light in and have no power to the plug sitting above the pedal and no fuses are blown.
any ideas? :?
Post Posted: Tue Mar 29, 2011 12:35 pm
Check the fuse is getting power, then follow the wiring to see if it has power up to the light
helloo
Post Posted: Tue Mar 29, 2011 1:03 pm
nah no power to the lights or to the switch above the brake pedal
is the fuse in the fuse box because there all good.
Post Posted: Wed Mar 30, 2011 12:22 pm
it should be in the fuse box, check the legend on the back or inside of the fuse box for brake lights. Have you tried a different fuse ? start at the power source (fuse box) then work it from there. if theres power at the fuse then its a broken cable.
it should go from fuse box to the switch then to lights.
Users browsing this forum: No registered users and 371 guests
