It is currently Thu Nov 05, 2026 3:10 pm
Post Posted: Fri Apr 01, 2011 12:43 am
Just wanting to know what water temp a 1.3 will run at as I am putting a after market gauge in.
Cheers joel
Post Posted: Fri Apr 01, 2011 1:01 am
Cheers joel
After you fit it go for a drive, after about 20mins look at the gauge, that's what temp it will run at. :wink:
SS
Post Posted: Fri Apr 01, 2011 1:08 am
1) What thermostat are you running?
2) Where do you plan to mount the gauge sender.
The first determines what temperature the engine will run at, the second will determine how close to the actual engine temperature the gauge will indicate.
Post Posted: Fri Apr 01, 2011 1:18 am
Cheers joel
That will depend on how hot it gets.
Post Posted: Fri Apr 01, 2011 3:59 am
90 from cold will go to 100 then the thermostat will open then go to 90
if u drive a loud toyota ute u drink rum
Post Posted: Fri Apr 01, 2011 6:40 am
mine ran at 80, or 87, cant quite remember
Users browsing this forum: Google [Bot] and 75 guests
