It is currently Sat Oct 24, 2026 12:03 pm
Vehicle: '94 Stockman Trayback
Post Posted: Mon Apr 11, 2011 10:49 am
thanks now sorted
Post Posted: Mon Apr 11, 2011 3:23 pm
First things first, I wouldn't be putting 91RON fuel in my Sierra... 95 minimum...
I want my old sig back :(
Post Posted: Mon Apr 11, 2011 6:46 pm
We are paying $1.70 per litre for 91 octane, here. 95 is strictly for the rich in these parts.
Post Posted: Mon Apr 11, 2011 7:02 pm
Try flushing your fuel system. Could be crap in the tank.
Post Posted: Mon Apr 11, 2011 7:39 pm
i used to find that different servos used to affect my old liberty i used to run 98 in it.If i put caltex vortex i used to get a big serge when i put my foot down. but bp and shell 98 were sweet never uesd to get a serge was just clean acceleration. it wasnt just a one off so i just stopped buying caltex fuel.
Post Posted: Tue Apr 12, 2011 12:29 am
Its up to you but I know my Sierra runs like a dog on any 91RON fuel... for 4c a litre extra 95 is worthwile... And for 10c so is 98 really...
Post Posted: Tue Apr 12, 2011 12:51 am
I get 98 no matter what. The fuel consumption of a Sierra isn't crazy enough to warrant going cheaper in my eyes.
Post Posted: Tue Apr 12, 2011 12:58 am
Check tank breather and carbon cannister,
if after taking cap off, it runs good,
and runs bad after a fair amount of driving,
fuel tank can vapour lock could be issue.
If it goes woosh when you take cap off, breathing could be the issue.
Also filling up can disturb the crap in bottom of tank.
Sometimes rough roads can disturb crap in the tank, too.
Post Posted: Tue Apr 12, 2011 1:23 am
So that whoosh sound isn't meant to happen!?
Post Posted: Tue Apr 12, 2011 1:25 am
you lucky bastard, i wish that i could get it that cheap. :cry:
Post Posted: Tue Apr 12, 2011 1:30 am
No it isn't under normal conditions.
Drive with cap loose, see if it improves.
Some Sierras had a vented cap, some didn't, that could be an issue.
If it appears to suck inwards,
then air can't get back in tank when fuel sucked out.
If it blows outwards,
then heat build up/pressure in tank is not being released.
My old Sierra had a blocked breather,
when parked in sun, it would force fuel out thru carby.
My problem was in the carbon cannister.
Post Posted: Tue Apr 12, 2011 1:33 am
Right. I thought it had something to do with the fuel system being under pressure.(just assumed it was because of the whoosh noise)
I may suss my breather and carbon canister out then. So is the breather the smaller tube that runs with the filler pipe?
Post Posted: Tue Apr 12, 2011 1:42 am
That is most likely fuel return line, unused fuel is pumped back in tank.
the breather breathes thru the carbon cannister, idea being it collects fuel vapour to be re used.
But different models go about it different ways.
If no breather pipes, then put a vented cap on
Post Posted: Tue Apr 12, 2011 1:55 am
I'll look in my service manual.
Post Posted: Tue Apr 12, 2011 4:09 am
I am having the whoosh but I would prefer the surge.
If it was the BP fuel then it would have mixed with the other stuff pretty quickly meaning the whole tank would have given the same performance which it didnt.
Do carby's and fuel pumps lose efficiency over time as they wear or do they just work or not work?
Post Posted: Tue Apr 12, 2011 4:16 am
Why?
Post Posted: Tue Apr 12, 2011 4:32 am
Does it normally run sweet at <1/2 a tank?
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Tue Apr 12, 2011 5:13 am
No, it has never done that before (if anything she was running sweet at more than half a tank not less). I would like it to do that all the time; never thought she had it in her. :D
Post Posted: Tue Apr 12, 2011 5:26 am
Well imma thinking you may have something floating around your tank/carby or even a fuel pick up issue. Sounds like a bit more than just a bad batch of fuel to me
Lil Foot!
Users browsing this forum: Google [Bot] and 117 guests
