It is currently Thu Oct 22, 2026 2:56 am
Post Posted: Fri Apr 30, 2010 10:38 pm
hey, just wonderin if anyone has done it and has tips on the best place to join the wires and wiring color info??
thanks
Post Posted: Fri Apr 30, 2010 11:01 pm
Wiring colours:
Red: brake
Brown: tail
Yellow: left
Green: right
White: earth
Black: reverse
Blue: auxilary
Can't help you with wiring up but I would suggest in behind the tail lights. You may be able to trace the loom to a junction point on the chassis
Post Posted: Sun May 09, 2010 1:11 am
thanks, has anyone got the wiring diagram for the actual car? ive found the loom there's one on either side.
Post Posted: Tue Apr 12, 2011 2:05 am
Just went too wire mine. Found a whole load of wires near where the jack goes. So guessing i need too wire in there. Which wires any ideas ?
Feral
Building Want37sLuxDisguisedSierra
Vehicle: 4wd
Post Posted: Tue Apr 12, 2011 3:06 am
http://auszookers.com/index.php?name=Ne ... cle&sid=38
Watch out or you'll get sued.
Post Posted: Tue Apr 12, 2011 4:20 am
Feral
Do you have a test light? That's the easiest way to determine which wire is which. If not, trace the wires back from the back of each light to where you want to join.
Post Posted: Tue Apr 12, 2011 8:54 am
Found a wire diagram in the end for the Gv, chop chop bit of soldering later and we're in buisness.
Thanks for your help
Users browsing this forum: No registered users and 155 guests
