It is currently Thu Oct 22, 2026 9:19 pm
Post Posted: Tue Apr 12, 2011 12:44 am
hey guys ive got a cab lift in my sierra and the radiator is now leaning against the front clip and has rubbed throughalong the top how do sierra owners fix this problem from happening to the new radiator, should i somehow bend the brackets for the rasiator back so it sitting off the body cheers luke
p.s can get pics if you like
Post Posted: Tue Apr 12, 2011 12:59 am
Loosen off the 4 bolts for the radiator brackets, then push the mounts away and see how much that gives you.
Was there any drama's in fitting the bodylift? Everything lined up fine?
I used to run some sticky foam between my rad and body with a different radiator setup. But with stocko 1.3 radiator, you shouldnt have a problem.
Post Posted: Tue Apr 12, 2011 1:00 am
There is some forward/back adjustment in the rad brackets where they bolt to the chassis. The top holes are slotted, so if you loosen the bolts off a bit you might be able push it back far enough that it clears that panel at the front. I would check your fan to rad and fan to shroud clearance before firing it up though.
Post Posted: Tue Apr 12, 2011 7:09 am
yer thanks guys i have a thermo fan its a bit thinner without the fan shround so should be all good i will loosen off bolts and try that cheers
suzuki sj70+2 inch lift+ 2ich body lift+ el falcon
Users browsing this forum: Google Adsense [Bot] and 366 guests
