| Diff oils http://auszookers.com/forum/viewtopic.php?f=5&t=20969 |
| Author: | TryHard [ Wed Apr 13, 2011 9:05 am ] |
| Post subject: | Diff oils |
ok well now that my car will be duel locked soon .. and my trans/gearbox / difs are full of water i am going to change all the oils ... now my question is does anyone know a good oil what do u use.. iv been useing some brand called Nulon .. i think its a pritty cheap brand any sugestion to what is best thanks |
| Author: | bohuler [ Wed Apr 13, 2011 9:10 am ] |
| Post subject: | Re: Diff oils |
with a locker you want to use a lim slip oil, personally i used penrite lim slip, i think its and 80/90, but seeing i have an open atm, havn't used it for about 3 years |
| Author: | CairnsZook [ Wed Apr 13, 2011 9:10 am ] |
The brand of oil won't matter if you don't put breathers on your diffs, g-box and t-case... They'll just fill up with water again |
| Author: | TryHard [ Wed Apr 13, 2011 9:55 am ] |
CairnsZook wrote: The brand of oil won't matter if you don't put breathers on your diffs, g-box and t-case...
They'll just fill up with water again haha yer thats a must do haha |
bohuler wrote: with a locker you want to use a lim slip oil, personally i used penrite lim slip, i think its and 80/90, but seeing i have an open atm, havn't used it for about 3 years
tought so |
| Author: | swifty_ano [ Wed Apr 13, 2011 10:06 am ] |
Can you use Lim Slip in an Open? |
| Author: | boostedbrick [ Wed Apr 13, 2011 10:09 am ] |
TryHard wrote: bohuler wrote: with a locker you want to use a lim slip oil, personally i used penrite lim slip, i think its and 80/90, but seeing i have an open atm, havn't used it for about 3 years tought so Dont use lim slip... I change my oils so often that i use the cheapest 80/90 i can find... Whice nowdays is that Repco 5ltr stuff for gearbox/transfer and castrol lim slip for diffs.. |
| Author: | mnemonix [ Wed Apr 13, 2011 10:12 am ] |
I use the same Penrite Hypoid 80w-90 in diffs/gearbox/transfer. Never had an issue. |
| Author: | CairnsZook [ Wed Apr 13, 2011 10:31 am ] |
boostedbrick wrote: ... I change my oils so often that i use the cheapest 80/90 i can find...
Exactly Using an expensive oil and thinking it will last longer is a false economy. Especially if it becomes contaminated with water/mud/grit/sand/whatever. Fit breathers and change your lube oils regularly and the internal parts and seals will all last significantly longer. |
| Author: | royce [ Wed Apr 13, 2011 11:21 am ] |
there was a thread a while back with info on using an oil with the right GL number for the box, you need one that is GL4 for the box and GL5 for the rest, so you dont toast teh syncros |
| Author: | Taylor74 [ Wed Apr 13, 2011 11:47 am ] |
Just make sure you use a 75w80 or castrol vmx 80 in your gear box. The syncros will work much better if you do. The rest 80w90 as cheep as you can get |
| Author: | Scrawny [ Wed Apr 13, 2011 5:40 pm ] |
royce wrote: there was a thread a while back with info on using an oil with the right GL number for the box, you need one that is GL4 for the box and GL5 for the rest, so you dont toast teh syncros
Castrol EPX80W90 is GL5 rated but designed for transaxle gearboxes, so can be used for synchros too |
| Author: | zuk85 [ Wed Apr 13, 2011 6:31 pm ] |
Taylor74 wrote: Just make sure you use a 75w80 or castrol vmx 80 in your gear box. The syncros will work much better if you do. The rest 80w90 as cheep as you can get
i can vouch for this stuff just put it in my jimny and the shifting it sooooo much easier cant believe the difference it made. |
| Author: | Scrawny [ Wed Apr 13, 2011 10:09 pm ] |
zuk85 wrote: Taylor74 wrote: Just make sure you use a 75w80 or castrol vmx 80 in your gear box. The syncros will work much better if you do. The rest 80w90 as cheep as you can get i can vouch for this stuff just put it in my jimny and the shifting it sooooo much easier cant believe the difference it made. Did you use the VMX80? |
| Author: | swifty_ano [ Thu Apr 14, 2011 6:18 am ] |
Ok sorry for the hijack. When I bought my car I got given 2L of "castrol rear axle LSX90" oil. Is this sustable for a 1996 vitara with open diffs? Is 2l enough? |
| Author: | Scrawny [ Thu Apr 14, 2011 6:27 am ] |
The LS means Limited Slip, so your oil is designed for a limited slip diff. Having said that, it won't adversely effect the diff, and being a 90W is about right |
| Author: | royce [ Thu Apr 14, 2011 6:33 am ] |
ive go that in mine, 2l will do the rear diff easy enough |
| Author: | swifty_ano [ Thu Apr 14, 2011 6:37 am ] |
Yeah it says Limited slip on the bottle... Don't wanna let it go to waste. So roughly 2l per diff? Thanks fellas! |
| Author: | swifty_ano [ Thu Apr 14, 2011 6:38 am ] |
Can I use it in my front? |
| Author: | Scrawny [ Thu Apr 14, 2011 7:18 am ] |
swifty_ano wrote: Can I use it in my front?
Yep |
