| What Carb? http://auszookers.com/forum/viewtopic.php?f=5&t=21018 |
| Author: | zukmeista [ Fri Apr 15, 2011 12:57 am ] |
| Post subject: | What Carb? |
No this isn't about webers [img][IMG]http://img17.imageshack.us/img17/898/suzuki024.jpg[/img][/img] [img][IMG]http://img251.imageshack.us/img251/3870/suzuki026.jpg[/img][/img] [img][IMG]http://img840.imageshack.us/img840/3324/suzuki025.jpg[/img][/img] |
| Author: | BlueSuzy [ Fri Apr 15, 2011 1:05 am ] |
| Post subject: | Re: What Carb? |
Vit 1.6 carb? No adaptor plates? |
| Author: | zukmeista [ Fri Apr 15, 2011 1:29 am ] |
Spacer at the bottom. |
| Author: | JrZook [ Fri Apr 15, 2011 1:48 am ] |
Vit carbs usually mikuni's have a plastic fuel bowl. Looks to me like an asian, very similar to the stock 1.3 unit |
| Author: | Fity [ Fri Apr 15, 2011 1:56 am ] |
Vit carbs also have more then 1 wire connection. My guess is a Sierra carb and maybe a N/T, Can't see any extra wires for the switch on the front which W/T have. |
| Author: | zooky08 [ Fri Apr 15, 2011 2:51 am ] |
Looks to me a standard 1.3 carb |
| Author: | FullyZooked [ Fri Apr 15, 2011 3:18 am ] |
Def not a Vitara mikuni. |
| Author: | stockman [ Fri Apr 15, 2011 3:38 am ] |
It looks similar to standard 1.3 aisin. Bit it looks like it has a manual choke. |
| Author: | shakes [ Fri Apr 15, 2011 8:26 am ] |
might be a silly question. but what motor is it on? |
| Author: | FHA57 [ Fri Apr 15, 2011 9:35 am ] |
its a 1.3 sierra carb |
| Author: | shep [ Fri Apr 15, 2011 9:41 am ] |
1.3 sierra carb with the auto choke stuff removed. looks like mine. |
| Author: | suzookyman [ Fri Apr 15, 2011 10:24 am ] |
its twin throat and has a 10mm spacer also has "aisin" on it, but is it standard?, original top won't fit and requires a spacer as well. Al its on this
| Author: | Taylor74 [ Fri Apr 15, 2011 11:32 am ] |
Looks like it might be an early Galant carby mitsubishi used alot of asin carbys back in the early days. I could be wrong havent worked on one for many a years now. |
| Author: | shep [ Fri Apr 15, 2011 11:56 am ] |
are you sure it is a 1.3 carby hat you are trying to fit? |
| Author: | Ben_Sierra [ Fri Apr 15, 2011 12:07 pm ] |
Looks very similar, but not quite the same as my 1.3 carby... |
| Author: | Built4thrashing [ Fri Apr 15, 2011 12:30 pm ] |
sierra carby. Pre polution. possibly off a Drover |
| Author: | shep [ Fri Apr 15, 2011 12:30 pm ] |
this is my stock 1.3 carb with a few unnecessary bits pulled off.
looks like the same carb to me. |
| Author: | Ben_Sierra [ Fri Apr 15, 2011 12:51 pm ] |
Built4thrashing wrote: sierra carby. Pre polution. possibly off a Drover
That'll be the difference then... |
| Author: | skyman [ Fri Apr 15, 2011 2:56 pm ] |
You guys got carbs with bigger throat tha we did her i the states on our 1.3's wonder if your 1.3's have a little more "giddy' 'yup" than ours due to the carb differences.. |
