It is currently Fri Oct 16, 2026 5:30 pm
Vehicle: Jimny
Post Posted: Fri Apr 15, 2011 10:37 pm
whats the difference between the two? and how can you tell? i bought and 89 model sierra jx and was wandering if it a narrow or a wide track
Post Posted: Fri Apr 15, 2011 10:41 pm
quickest way
wt's have large flares about 3" wide normally metal (there was a plasitic versionbut they are rare) and painted.
nt flares are about 30mm wide and platic
Look at the front chassis rails. Nt has he shackle perch directly right under the chassis. Wt have them offset out alittle to the chassis.
Yours should be WT. Metal flares.
Post Posted: Fri Apr 15, 2011 10:42 pm
If you can fit beween bollards they put to stop you driving somewhere, or if you can drive over a pedestrian bridge, its a narrow track :peaceout:
Or have a squizz at the leaves, if they are mounted under the chassy, its a narrow track, if they are mounted on the outside of the chassy, offset wider then the chassy, its a wide track :D
Dave
Vehicle: Jimny
Post Posted: Fri Apr 15, 2011 10:51 pm
Post Posted: Fri Apr 15, 2011 11:02 pm
Looks like a widetrack.. I would say around a 94 model..
Post Posted: Fri Apr 15, 2011 11:05 pm
Dude thats a mix..
94'+ guards
89' grill
Vit wheels
Post Posted: Fri Apr 15, 2011 11:08 pm
Yeah was gonna say, my 93 had the same grill as my 95
Vehicle: Jimny
Post Posted: Fri Apr 15, 2011 11:12 pm
its an 89 model.
DONT BUY A GQ! zooks are better. i have both :)
Post Posted: Sat Apr 16, 2011 12:00 am
Widetrack
My Maruti build, Click WWW
Users browsing this forum: Google Adsense [Bot] and 223 guests
