http://auszookers.com/forum/
wiring
http://auszookers.com/forum/viewtopic.php?f=5&t=21061
Author:  russty_2008 [ Sat Apr 16, 2011 1:26 pm ]
Post subject:  wiring
ive been looking for hours does anyone have the pinout for a 96 baleno (with dizzy) its a 6k 1.6 e24 33920-60gm1 112000-3081 12v denso
Author:  MrRocky [ Sat Apr 16, 2011 10:26 pm ]
Post subject:  Re: wiring
try this and scroll down
http://www.redlinegti.com/forum/vt.19261.htm
Author:  want33s [ Sat Apr 16, 2011 11:28 pm ]
None of those links work.
Author:  russty_2008 [ Sun Apr 17, 2011 10:37 am ]
Where is the tacho meant to be hooked up to
Author:  skyman [ Sun Apr 17, 2011 1:44 pm ]
If you are looking for the tacho lead under the bonnet it is the solid brown wire found near your coil and distributor.
If you are looking for it under the dash I can't help, mine was plug and play in the interior.
Author:  MrRocky [ Sun Apr 17, 2011 2:01 pm ]
you can open the ecu cover and written on the circuit board
should be a symbol tach next to one of the pins from memory.
im pretty sure thats the one i used for the signal or it might have been from the coil ? sorry its been quite a while since ive done it, the details are a bit fuzzy
Author:  want33s [ Sun Apr 17, 2011 8:31 pm ]
There ya go Russ... Good luck....
