It is currently Wed Oct 14, 2026 6:52 pm
Post Posted: Sun Apr 17, 2011 4:44 am
G'day fellow demented auszookers
We've just wacked an EFS 50mm Suspension Lift in my Girls 00' model jimny. And now the Arse end on the Left hand side is sitting 30mm Taller than the Right hand side.
Wtf Could cause this???
Stocker
Post Posted: Sun Apr 17, 2011 4:46 am
Got the coils in the right side?
Post Posted: Sun Apr 17, 2011 4:49 am
Is there a right and wrong side???
I thought they would be the same being a live axle and all???
Stocker
Post Posted: Sun Apr 17, 2011 4:52 am
Yep. I just look at my TD srpings and they have D/S (drivers side) and P/S (passenger side) written on them. Swap them over and see how it goes.
Post Posted: Sun Apr 17, 2011 4:57 am
also is it seated right??
mine sat about that much higher after i jacked up the car to put in the shocky brackets in the rear and the spring moved out of place
Post Posted: Sun Apr 17, 2011 5:00 am
yes, covered that base, definitly seated right, and we've taken it for a few good runs up and down a rough track just incase it just needed to be bedded in a bit better, will try swapping the springs around and see if that fixes it... has anyone else had this problem???
Stocker
Post Posted: Sun Apr 17, 2011 5:01 am
rear right side spring is longer.
Post Posted: Sun Apr 17, 2011 5:51 am
any news??
Post Posted: Sun Apr 17, 2011 6:40 am
my brother and i are pulling it out now and swapping the coils now...
we just finished the Calmini kit in my Vitara, i'll post up some photo's later :)
Stocker
Post Posted: Sun Apr 17, 2011 7:05 am
exact same thing happened to me.
swap rear springs. solved.
also make sure the curly, pig til end of the spring is about 1 cm away from the steel bit on the axle, cant really explain it that well sorry. you will know if its wrong, cause every time it flexs you will hear massive, creaking noises.
Post Posted: Sun Apr 17, 2011 7:14 am
thanks fella's swapped coils round, and now sitting Flat. and i now have a very happy girlfriend :)
cheers again
Stocker
Post Posted: Sun Apr 17, 2011 7:17 am
pics mate??
Post Posted: Sun Apr 17, 2011 7:27 am
cheers again
ask for anal!!!! :twisted: :twisted:
Post Posted: Sun Apr 17, 2011 8:35 am
dm90 wrote:
cheers again
hmmmm..... thats gives me an idea.. will give it a go
Post Posted: Sun Apr 17, 2011 8:41 am
What better opportunity! Wanna see pics and of calmini Vitara!
Post Posted: Sun Apr 17, 2011 9:24 am
dm90 wrote:
cheers again
you should really specify who's arse is about to get penetrated ;)
:evil: "Ra" My now Calmini Vitara Flexes like a demon :evil:
I just need to get the Training wheels out from under it and some 31's instead :)
Stocker
Post Posted: Sun Apr 17, 2011 9:30 am
PICS of jim and vit?
Post Posted: Sun Apr 17, 2011 12:43 pm
Prefer pix of anal 8O :oops: :roll: :wink: :blink: :D
Users browsing this forum: No registered users and 318 guests
