| Author |
Message |
SierraEchoX-ray
Joined: Thu Mar 03, 2011 6:34 am Posts: 38 Location: Sunshine Coast
 Posted: Sun Apr 17, 2011 10:56 am |
Hey guys, ordered some EFS U-bolts for the front of my SJ40 NT and i was replacing the outer passenger one and noticed it is a different size. Havent checked the drivers side one yet so i thought i might ask before i take it off for an exact comparison.
Are the U bolts between the Narrow Track and the Wide track different?
part numbers i have currently...
C655-passenger side
C654-drivers side
any help would greatly be appreciated
Karl
Joe
Joined: Sat Jul 04, 2009 11:30 pm Posts: 49041 Location: Rockingham W.A
 Posted: Sun Apr 17, 2011 11:10 am |
303zuke wrote: LJ50, LJ80 and SJ40 all have small diameter axle tubes than the 1.3 Sierras, so the bolt pattern on the spring plate is smaller spacing and the bolts a smaller width. They are a smaller thread and nut with smaller bar size.
_________________ Joe likes boobs ( . )( . ) ( ° )( ° )
SierraEchoX-ray
 Posted: Sun Apr 17, 2011 11:16 am |
Thanks very much for that!
I will contact the supplier tomorrow and see if there is a listing for them
303zuke
 Posted: Sun Apr 17, 2011 2:32 pm |
It's not that it's a narrow track, it engine size and axle tube thickness.
The 1.0lts have smaller axle tubes and U-bolts to both the NT 1.3 and the WT 1.3.
Even though they are both Narrow Track Sierras, there are plenty of detail differences between the NT 1.3 and the 1.0 Sierra, and you shouldn't assume that all bits are the same.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13011 Location: Melbourne
 Posted: Sun Apr 17, 2011 9:43 pm |
WT and NT sierras have a different driver's side inner U bolt due to the different spring pad spacing. On the NT, the U bolt is longer because it sits further up the diff pumpkin.
SierraEchoX-ray
 Posted: Mon Apr 18, 2011 11:43 pm |
Thanks for the info guys. Called the guys who supplied me with the U bolts, they said that there was only one listing for sierra's in his book. He is going to find out more today and hopefully find the right bolts.
tonyevans
Joined: Sun Jan 16, 2011 11:18 pm Posts: 1998 Location: Lightning Ridge NSW
 Posted: Mon Apr 18, 2011 11:53 pm |
SierraEchoX-ray wrote: Thanks for the info guys. Called the guys who supplied me with the U bolts, they said that there was only one listing for sierra's in his book. He is going to find out more today and hopefully find the right bolts.
If it's the same guy I got mine from (and I had the same problem) I got the same excuse and he wanted me to pay $50 extra to get the right size made up so I found the information he needed for stock ones and he said he would "Continue his research into it" - Very impressed NOT.
_________________ Old farts sometimes know some stuff you don't.
SierraEchoX-ray
 Posted: Tue Apr 19, 2011 5:41 am |
The guy i ordered them through is a family friend and always very helpful. I took down some rough measurements and called him back. He said that they didn't match up with anything from Iron Man or EFS.
Has anyone ever replaced theirs and possibly still have the part numbers?
The reason i am replacing them is because one of the previous owners has put some other U bolts in and they are to long and i am worried about them catching on rocks or something....worse case scenario i get the angle grinder onto them.
tanshi
 Posted: Tue Apr 19, 2011 5:46 am |
efs, do them cos thats where i have bought mine from.
call carrolls springs
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
 Posted: Tue Apr 19, 2011 6:45 am |
Can I ask why not Buy a different brand?
Or do you have efs springs already on your car
_________________ 03 Jimny 30 km2s 75mm lift f&r locked winch
SierraEchoX-ray
 Posted: Tue Apr 19, 2011 7:00 am |
Thanks Tanshi. Just emailed them
well i was planning on buying through my friends business and he stocks EFS and said they were a good brand to go with. Haven't really inquired any other places cause i have been busy lately.
