Joined: Wed May 21, 2008 11:30 pm Posts: 4972 Location: Dandenong .Vic
Posted: Tue Apr 19, 2011 6:35 am
depending on axle size you may need to get special adaptor bearings to allow you to use the bigger style hub on a smaller axle. You can do it as i did it on my old zook trailer.
Joined: Sat May 19, 2007 11:30 pm Posts: 2535 Location: Perth
Vehicle: 93 Sierra
Posted: Tue Apr 19, 2011 7:16 am
F100 hubs run Ford SL bearings, which are too big for your normal 39mm round axle (which run Holden LM bearings). You might be able to get adaptor bearings like B4T says (not sure) - but another solution is to get a 45mm square axle made up for the specific track width you want, and that'll then fit the SL bearings and F100 hubs.
45mm square axle does weigh a bit more than the 39mm round but also has much higher rated capacity (1400kg vs 750kg).
Joined: Sun Sep 07, 2008 11:30 pm Posts: 2689 Location: North Brisbane
Posted: Tue Apr 19, 2011 8:14 am
Someone must do them with the holden size bearings, I sold a trailer just before Christmas with suzuki stud patern I replaced the bearing from supercheap and they were the normal holden size ones. i believe that you can also buy blanks that you drill the stud patern yourself.
Users browsing this forum: Google [Bot] and 151 guests
