It is currently Thu Jul 30, 2026 8:45 pm
Vehicle: SWB Vit & LWB GV
Post Posted: Wed Apr 20, 2011 12:13 am
Hi there,
The speedo has been playing up the last couple of days. It's been jumping around, clicky and I think this morning it's f'd. It's reading about 5-10km/h less than it normally should.
I've tried searching, but I can't find anything specific for the Vitara speedo cable.
I tried taking the cluster out last night, but had massive dramas taking the steering wheel off, so I gave up.
Any help would be appreciated.
stock as a rock
Post Posted: Wed Apr 20, 2011 12:16 am
to get the wheel off
there is a screw in teh wheel that you pull out and pull the whole center off
undo the nut in the middle, but only loose, dont remove it
with a fist at 3 and 9 o'clock, smach crap out of the front face of the wheel, this should shock it off the spline
undo nut and slide wheel off
though the cluster should come out without it
Post Posted: Wed Apr 20, 2011 12:18 am
I'll give that a go.
Any advice re speedo cable?
stock as a rock
Post Posted: Wed Apr 20, 2011 12:29 am
you could undo it from the transfer end, slip the inner out and have a look at it and see if its broken anywhere, give it all a spray with silicone spray and stick it back in and see how it goes, pays to have somebody with you to see if it seats in the speedo end when you refit it (spin the inner gearbox end and see if the speedo flickers)
though reading low sounds like a prob in the cluster
Users browsing this forum: Google [Bot] and 330 guests
