It is currently Mon Sep 21, 2026 11:52 pm
Post Posted: Wed Apr 20, 2011 6:48 am
Great site It actually helped me decide on the zook.Have been a visitor a few times but now needing some serious advice. Own a 1996 Maruti tray and some dirt so this has been the best buy after having rolled an atv on flat gnd :blink:
Probably would have saved a hit from a red light camera last week too
The starter has just begun to whir? and not turn the engine (intermittent)
Noticed it will start the engine while in gear, clutch out (stuck so had to try all
options). Battery ok ignition ok wiring ok
Also the question is how do I get the flammin starter out (1Lt Engine)
Can I get it up through the hoses or do they have to come off. Any other ways
Sorry men I do elect not mechanics.
Really hoping to do some off road this break but .........
Appreciate your thoughts Thanks
Post Posted: Wed Apr 20, 2011 7:21 am
Hi mate. Welcome.
The starter needs replacing. It is held in by 2 bolts that go into the gearbox bellhousing. Just undo the wires that are attached to the starter, and remove the 2 bolts. You should be able to do this from above.
Pete
Post Posted: Wed Apr 20, 2011 9:09 am
Hi mate. Welcome.
The starter needs replacing. It is held in by 2 bolts that go into the gearbox bellhousing. Just undo the wires that are attached to the starter, AFTER DISCONNECTING THE BATTERY and remove the 2 bolts. You should be able to do this from above.
Pete
:wink:
Post Posted: Wed Apr 20, 2011 9:13 am
^^^ yes disconnect the posative on the battery first
Post Posted: Wed Apr 20, 2011 9:17 am
Thanks Fatzook
When you say starter needs replacing.
What do you think might be the fault with the starter that it cant be fixed.
Just that funds are a bit ordinary at the moment.
So thought I might be able to have a go at it, of course as long as it isnt the
wiring inside.
Neil
Vehicle: 03 Jimny
I had the same problem I reckon
Starter wouldn't turn engine over only in gear
Try retard your timing abit until she winds over
If it does work then it's stuff like fatzook said
Post Posted: Wed Apr 20, 2011 10:29 am
neg first, always neg first when disconnecting......
pos on first.........
Post Posted: Wed Apr 20, 2011 10:33 am
redrockrover wrote:
Thanks Fatzook
wiring inside.
Neil
Its not worth the trouble.
I'd wager that the magnetic switch is not 'throwing' the pinion gear as it should. This happens when everything inside the starter wears out.
If it were just making a clicking noise, you could replace the solenoid. But yours sounds terminal :cry:
Users browsing this forum: No registered users and 159 guests
