It is currently Wed Oct 07, 2026 6:24 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2  Next
Post Posted: Sat Apr 23, 2011 10:15 am
Just got a Arb winchbar for my Sierra and just wondering what winches fit in it other than the warn ones.
Also after some pictures of beefed up chassis mounts for when you cut the out rigers off.
My Maruti build, Click WWW
Vehicle: 03 Jimny
Post Posted: Sat Apr 23, 2011 4:06 pm
I also wanna know this
Post Posted: Sat Apr 23, 2011 9:09 pm
i have the aldi 9500 pound winch in mine its a very tight fit but all i did was get a pair of vice grips(duck bill) and just bent the back returns out from 90degress to about 70 degress where it needed it. oh and best recovery item you could ever have :)
Post Posted: Sat Apr 23, 2011 10:51 pm
Have a look in here
http://auszookers.com/index.php?name=Fo ... ic&t=20991
and here
http://auszookers.com/index.php?name=Fo ... bar+mounts
My Rig --> Click WWW
Post Posted: Sat Apr 23, 2011 11:38 pm
I've been told at Arb a 6000 warn is the only one that fits
Post Posted: Sun Apr 24, 2011 12:16 am
tabor 9k fits i believe,
dodgy brothers mechanical
also avengers new 9000 pund winch is a pretty small unit, that should fit
Vehicle: 03 Jimny
Post Posted: Sun Apr 24, 2011 1:44 am
What about tiger 11 9000lb winch
Post Posted: Sun Apr 24, 2011 6:49 am
only one that will be warrantied in the event of a failure to the bar or chassis.
Post Posted: Sun Apr 24, 2011 9:16 am
mad zook runs a 8500 warn in his
 Profile YIM
Post Posted: Sun Apr 24, 2011 9:20 am
You guys are overlooking one VERY important thing here.
The bar is not DESIGNED for more than a 6000lb winch. The mounts are far too light duty for a 9000lb winch.
Vehicle: 03 Jimny
Post Posted: Sun Apr 24, 2011 9:31 am
Mine won't have the mounts that the bar comes with :wink:
Post Posted: Sun Apr 24, 2011 9:38 am
Not just the mounts mate. The bar too!
6000lb is enough to get a zook out of trouble.
Post Posted: Sun Apr 24, 2011 9:40 am
6000lb = 2.7tonnes - thats enough to pull 2 overloaded sierras out =)
Tis. I've seen it done :wink:
Post Posted: Sun Apr 24, 2011 9:41 am
i have a 6500lb jobbie and it is plenty big enough for a zook.
Vehicle: 03 Jimny
Post Posted: Sun Apr 24, 2011 9:44 am
So if I have a 9000lb in a arb and only pull out Sierra or vitaras, it still won't hold up?
Post Posted: Sun Apr 24, 2011 9:48 am
Who knows. It may just shorten the life of your bar and or chassis. All I am saying is that the bar is not designed for that sort of load. And given ARB's mounting system ON THE SIERRA, I would not like to find out the hard way.
Vehicle: Daisy
Post Posted: Sun Apr 24, 2011 9:52 am
As a side note, what is the strongest winch you would think safe to mount on a zook? Do you sell winch bars yet?
If this is not the place I can take it to the business thread or PM, just figured while we're on the topic of winch size in a bar.
Vehicle: 03 Jimny
Post Posted: Sun Apr 24, 2011 9:53 am
Well I know how weak the arb bars are
I bent nd ripped the holes out of both the bar nd chassis
Dont ask :roll:
Post Posted: Sun Apr 24, 2011 3:56 pm
go for it zooky08, engineers design a safety factor into everything to handle twice the force intended to to placed on it. So if its rated at 6000 pounds, it breaks at 12000.
Post Posted: Sun Apr 24, 2011 3:57 pm
Dont ask :roll:
snatched with the unstretchable steel winch cable?
Post Posted: Sun Apr 24, 2011 5:18 pm
Dont ask :roll:
do you still have the "out riggers" ?
if not you only had 1/2 the number of bolts holding it on so you've only got yourself to blame.
Vehicle: 03 Jimny
Post Posted: Sun Apr 24, 2011 7:18 pm
Yea I blame my self 100%
was a stupid thing to do
Wasn't from winching
The outriggers were cut off from the previous owner
Post Posted: Sun Apr 24, 2011 10:09 pm
So how does that make the ARB bar weak?
It's like saying suzuki's are weak because my wheel fell off. I only had two wheelnuts on at the time though.
Vehicle: 03 Jimny
Post Posted: Sun Apr 24, 2011 10:52 pm
Well they are not weak if the are bolted up properly
Mine wasn't so I suffered the consequences
Post Posted: Sun Apr 24, 2011 11:44 pm
Was it because you didn't use the out riggers? Did you use crush tubes ?
Vehicle: 03 Jimny
Post Posted: Mon Apr 25, 2011 12:07 am
The arb outrigger mounts were cut of so that was half the strength I didn't have
The chassis is very thing nd it doesn't take much to rip the holes out
I had crush tubes
I was pulling my friend of a tree
The force ripped half my bar off
Was just Hanging of one side the chassis
Snapped two of the four bolts
And riped and bent my mounts on the bar
It really does pay to have all your mounts
But mostly don't snapstrap from your bar if only have half the mounts :roll:
Post Posted: Mon Apr 25, 2011 12:17 am
If you want to run all the mounts, then get used to running 29" tyres. :wink:
Post Posted: Mon Apr 25, 2011 12:22 am
my outriggers scrubbed on my 29's...
Users browsing this forum: Google [Bot] and 172 guests
