It is currently Wed Oct 07, 2026 2:22 pm
Post Posted: Sat Apr 23, 2011 10:53 pm
Hey guys i had this same problem with my last zook aswell, its when i drive threw muddy water i have no clutch i can press it in but id doesnt do anything. After about 10 mins of driving its ok but its a bit of a pain.
Does anyone elses zook do this.
My guess it that the clutch being only covered by a roughy fitted bit of metal that the gunk in leaking in onto the clutch surface.
Post Posted: Sat Apr 23, 2011 11:01 pm
so it's engaged all the time?
Post Posted: Sat Apr 23, 2011 11:02 pm
Do u still have the rubber plug that goes over the flywheel inspection hole? Mud gettin into ur bellhousing and fillin ur clutch would prob do exactly what ur sayin. Would take a little while for it to clear all the crap and allow the clutch to engage. Best idea would be to drop the box and clean it out (check ur clutch surfaces while ur at it - mud + clutches = :sad: ). Make sure it's well sealed when u reassemble (hell i'd even use some silicone to hold the rubber bung in so ya don't lose it lol).
Edit: if i'm reading what ur sayin right....
Don't change gear in water. Simple!
Post Posted: Sun Apr 24, 2011 10:46 am
Its not really a matter of changing gears or not, if i drive thru it happens. I will have a look and see if the plug is in or not
Post Posted: Sun Apr 24, 2011 10:57 am
I put a breather on mine,
and made sure it was well sealed up,
that solved mine.
Present car is Auto, thats even better :)
Post Posted: Sun Apr 24, 2011 9:06 pm
yeh i think i will pull it out and have a look, then sea it all up.
Users browsing this forum: No registered users and 219 guests
