| maxxis Trepador http://auszookers.com/forum/viewtopic.php?f=5&t=21395 |
Page 1 of 3 |
| Author: | ZUKOFHZRD [ Wed Apr 27, 2011 11:20 am ] |
| Post subject: | maxxis Trepador |
hi there, has anyone ever tryed the maxxis trepador, im looking at them in a 31/10.5/15 to go on my 87 sierra soft top, what would i need to go with them, the guy sed he can get me rims with neg 11 offset to push them away from anything that may rub, but im not sure if that will be enuf, im gessing reduction gears would be needed (its a 1.0ltr) but not sure of what ratio to go, in the future im planing on a 1.6 conversion, a 2'' lift will be fitted with the tyres |
| Author: | smiffkid [ Wed Apr 27, 2011 11:50 am ] |
| Post subject: | Re: maxxis Trepador |
if there going to be a 15x8 neg 11 that should be alright i think, u will need to modifie your bumper mounts and will need more then just 2 inch lift, gearing in those isnt to bad, just motors lack power, as far as im aware |
| Author: | zooky08 [ Wed Apr 27, 2011 11:52 am ] |
I'm just guessing here as I just bought treps today For a 1lt u will have to swap in a 1.3 transfer case for the gears A 15x8 rim with idea offset Not sure if you could fit 31 on stock height unless you get the grinder out haha |
| Author: | ZUKOFHZRD [ Wed Apr 27, 2011 11:57 am ] |
rims are 15x7 |
| Author: | ZUKOFHZRD [ Wed Apr 27, 2011 11:58 am ] |
you rekon 2'' aint enuf. hmmm might have to see once there on maybe throw a body lift at it |
| Author: | tanshi [ Wed Apr 27, 2011 11:59 am ] |
for 31s your going to need , 2 inch lift, bumpstops and a grinder. grinder on the buper mounts on the front and probably the bumper. and the hammer for the seams. 2 inch bumpstops, |
| Author: | zooky08 [ Wed Apr 27, 2011 12:01 pm ] |
2 inch suspension and virtual lift or 2 inch suspension and body lift Either one should do I reckon |
| Author: | ZUKOFHZRD [ Wed Apr 27, 2011 12:11 pm ] |
whats virtual lift? |
| Author: | zooky08 [ Wed Apr 27, 2011 12:17 pm ] |
Guard chopping |
| Author: | Gwagensteve [ Wed Apr 27, 2011 12:17 pm ] |
Virtual lift= Cutting guards. What's required to run 31's on a sierra gets covered about every 45 minutes on here. Another thread about it should be starting about...........................................now. 31's= 2" body lift and some guard clearancing. Maybe wheel spacers on a NT if you start playing with added wheel travel. Radial treps are nothing special. Bias treps are cool, but they start at 37" Steve. |
| Author: | SuziBlu [ Wed Apr 27, 2011 12:25 pm ] |
A virtual lift is where you chop the wheel arches/guards so as to get bigger tyres underneath, fair bit of work, but keeps the COG lower than with a body lift. |
| Author: | ZUKOFHZRD [ Wed Apr 27, 2011 12:26 pm ] |
yer 37s is probly a little large atm, so nothing a little grinding and bashing wont fix, kool kool |
| Author: | ZUKOFHZRD [ Wed Apr 27, 2011 12:27 pm ] |
how much of the gaurd needs to be chopped |
| Author: | Gwagensteve [ Wed Apr 27, 2011 12:30 pm ] |
Depends on lots of factors - wheel offset, actual tyre diameter, spring and shock configuration, bumpstop length... There's no hard and fast rule. Steve. |
| Author: | smiffkid [ Wed Apr 27, 2011 12:32 pm ] |
2 inch spring lift, then virtual lift will prob be enough, unless u want some massive flex or something |
| Author: | ZUKOFHZRD [ Wed Apr 27, 2011 12:36 pm ] |
Gwagensteve wrote: Depends on lots of factors - wheel offset, actual tyre diameter, spring and shock configuration, bumpstop length... There's no hard and fast rule.
Steve. fair enuf, i get where your coming from not looking for huge travel at the moment just going cheep for now and see where it takes me |
| Author: | monley [ Wed Apr 27, 2011 12:46 pm ] |
I seen a WT the other day that had, no lift, flat springs running 31's with no rubbing and i could not see and cutting been done either...i think it was just resting on the bump stops...
| Author: | ZUKOFHZRD [ Wed Apr 27, 2011 12:48 pm ] |
hmmm maybe i should by them and see, cant hurt, the rim to go with them was a 15x7 i was told it is fine witha 31/10.5/15 |
| Author: | alien [ Wed Apr 27, 2011 12:54 pm ] |
forget the treps, buy some kumho kl71s. |
| Author: | smiffkid [ Wed Apr 27, 2011 12:57 pm ] |
how did u find them in the wet aron, any good |
| Author: | ZUKOFHZRD [ Wed Apr 27, 2011 1:01 pm ] |
i work at a tyre shop and we are actualy kumho dealers, i was thinking of going the kl71 but i rang up maxxis today and i can get maxxis dirt cheep on a special deal, what makes the kumho's so much better |
| Author: | smiffkid [ Wed Apr 27, 2011 1:04 pm ] |
arons are incredible for a cheap tires and in my opinion the radial treps arent all that great compared to a non directional tires |
| Author: | ZUKOFHZRD [ Wed Apr 27, 2011 1:08 pm ] |
but the kl71 are directional aswell |
| Author: | TryHard [ Wed Apr 27, 2011 1:09 pm ] |
Horns or BF KM2s what kinda stuff u wanta drive |
| Author: | smiffkid [ Wed Apr 27, 2011 1:09 pm ] |
yea i know, im saying that the radial treps arent alot better then a non direction tire i.e coopers or bridge stone, |
| Author: | ZUKOFHZRD [ Wed Apr 27, 2011 1:13 pm ] |
arh k k, not a fan of bf, but i can get any maxxis on the same deal |
| Author: | alien [ Wed Apr 27, 2011 1:13 pm ] |
i own both km2 and kl71.... thus far the kl71 grip better on the road (wet and dry) and on rocks - i'm dying to test both in mud now! KM2 cheapest quote i had was $320 fitted (didnt pay that though). KL71 i got for $190 fitted. |
| Author: | ZUKOFHZRD [ Wed Apr 27, 2011 1:14 pm ] |
want to do evrything, sand mud rocks gravel |
| Author: | ZUKOFHZRD [ Wed Apr 27, 2011 1:15 pm ] |
what size was the kumho |
| Author: | ZUKOFHZRD [ Wed Apr 27, 2011 1:16 pm ] |
me mate has kl71s on his 75 ser cruiser and hes was saying they gripped well in the rocks at mundaring power lines |
| Page 1 of 3 | All times are UTC + 9:30 hours |
