It is currently Thu Oct 15, 2026 5:18 am
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2  Next
Post Posted: Wed Apr 27, 2011 12:21 pm
what are the standard tyres size for a sierra
THINKING BEFORE POSTING!!!
Post Posted: Wed Apr 27, 2011 12:24 pm
not sure but 26" i think
edit: beaten
Post Posted: Wed Apr 27, 2011 12:34 pm
H7815 for JX NT's
6.00X16 for "commercial" 1.3's and 1.0 litres.
205/70/15 for WT's (mid 1988 onwards)
Maruti's stuck with H7815 AFAIK.
Post Posted: Wed Apr 27, 2011 12:35 pm
cheers
edit: all of you
Post Posted: Wed Apr 27, 2011 12:37 pm
without gearing what should i put on my sierra, i wanna go as big as possible without any gear box probs is 30s pushing it
Post Posted: Wed Apr 27, 2011 12:44 pm
You won't have any gearbox probs. You'll just get sick of changing gears everytime there is a 1 degree incline or someone in the car infront farts, causing the resulting flatulant wind to slow your vehicle. :wink:
No bigger than 30's would be my vote.
Post Posted: Wed Apr 27, 2011 12:45 pm
30's is borderline depending on the terrain you drive.
Post Posted: Wed Apr 27, 2011 12:59 pm
I noticed 29's with my 1.3L
Choppy didn't as much with his 1.6L
I have 1lt transfer case now and its much better
My Rig --> Click WWW
Post Posted: Wed Apr 27, 2011 1:03 pm
215/75r15 if you want to keep a usable low range... if you're driving sand a 235 would be "get-away-with-able" in my opinion.
dont forget a 215/75r15 is 6.5% larger than factory... so when the speedo reads 100km/hr you're really doing 106.6 etc... same affects your lower down speeds... where right now you might do say 1000 rpm in 1st gear, crawling along... rev it to around 1100rpm and imagine that being the slowest you can go.
there comes a point where you're just going too fast to be controlled going over things and end up riding the clutch all day to keep it slow.
Post Posted: Wed Apr 27, 2011 10:53 pm
I got 30's with the standard 1.3 n gearing.
Hills r not your friend:/
Ended up in 2nd on the highway haha
If in doubt power out!
Post Posted: Wed Apr 27, 2011 11:07 pm
Geez.. I've got 31's and just barely had to drop back to 3rd up a hill.
But agree that it's crap without gearing mods. I wouldn't go up from 235's without gearing.
Post Posted: Thu Apr 28, 2011 4:10 am
Ive got 235 on mine .untouched gears.I can notice it but still very drivable on the highway and low range..wouldnt go any bigger..after awhile you forget what stockos drive like anyway.
Vehicle: 93 Sierra
Post Posted: Thu Apr 28, 2011 4:50 am
I had 235/75R15's on mine with stock gearing ... fine on the highway (better even) but not great offroad. Burnt way too much clutch saving the rest of the driveline.
Post Posted: Thu Apr 28, 2011 7:55 am
i dont realy care if i have to piss other drivers of by going slow, but i do care if ima need a new clutch. sigh i was thinking 28s but i wanna go bigger
recon the small tyres r gona look shite with a 4 inch lift
Post Posted: Thu Apr 28, 2011 7:56 am
Yep!
Post Posted: Thu Apr 28, 2011 8:11 am
Yeah that's a given. Stock tyres look crap on a TWO inch lift.
Post Posted: Thu Apr 28, 2011 8:32 am
My lwb has 215, 75, 15's and thats whats one the tire placard so i thought it was standard. Mine is an 85 n/t lwb and its also the smallest bfg will do a km2 muddy altho you can't get the buggers atm.
Dave
Post Posted: Thu Apr 28, 2011 8:53 am
Dave
I don't believe you. I have an 86 N/T LWB and it's H 78 15.
Personally, I think 215 is too small to spend money on. A 235 is a much better option.
Post Posted: Thu Apr 28, 2011 9:32 am
ok i stand corrected. i would of sworn that they said 215 :p So can you explain why the fu&*k don't they have the tyre size. WTF does FR 78-15 mean?
Could someone explain the number here?
Dave
Vehicle: LJ50V, SJ70
Post Posted: Thu Apr 28, 2011 1:12 pm
Dave
Can we see a pic of the H78 15 placard? I've always thought the JX NT's were FR78 Bridgestones?
Post Posted: Thu Apr 28, 2011 1:21 pm
Dave
FR78 15 is an older tyre size, but not as old as the 6.00-16 style sizing. The 78 means it is a 78% aspect ratio tyre, while sizes A, B, C etc get bigger. The R means it's a radial tyre. 15 is for a 15" rim. A FR78 15 is approximately equivalent to a 205/75-15. Note that the widetracks had a 205/70-15 tyre, which is lower profile than a FR78 and smaller diameter, which is why they changed from 3.9 diffs to 3.7.
6.00-16 is a 100% aspect ratio tyre that nominally is 6 inches in section width and 6 inches in height (although they are rarely exactly these dimensions) for a 16" rim.
Post Posted: Fri Apr 29, 2011 10:26 am
H7815 for JX NT's
So going by this the NT 1.3 was known as a commercial?
What measurement in our current sizes do these compare too?
EG a 30/9.5 or 29?? 31??
Post Posted: Fri Apr 29, 2011 1:34 pm
There were 2 spec levels for the NT Sierras, JA and JX.
JA was the commercial or basic version and had 6.00-16 bar tread tyres. The body had no flares, there was no Tacho or dash clock, vinyl floor mats and low-back seats.
JX had FR78-15 tyres, small rubber flares, Tacho and clock, carpets and cloth seats in Hard-top, full-floor mats in soft-top and better vinyl sears with headrests.
1.0 JA soft-tops had half doors (like Drover). Hi-roof was only available as JX
205/75-15 = 670mm = 26.4in.
FR78-15 = 690mm = 27.1in.
6.00-16 = 725mm = 28.1in.
Post Posted: Fri Apr 29, 2011 1:40 pm
http://www.turbinecar.com/tires.htm
has a good chart.
the 6.00-16 is what most people use to argue engineering a larger tyre size too, cos going from a 28 to a 31 is only a 10.7% increase rather than the 19.2% increase over a 205/70r15.
Post Posted: Fri Apr 29, 2011 11:57 pm
My bad - F78 not H78.
Post Posted: Sat Apr 30, 2011 11:10 am
:blink: TO MANY DIFFERENT NUMBERS :crazy:
Vehicle: LJ20 LJ50
Post Posted: Sat Apr 30, 2011 11:14 am
Dave
FR78 15 is an older tyre size, but not as old as the 6.00-16 style sizing. The 78 means it is a 78% aspect ratio tyre, while sizes A, B, C etc get bigger. The R means it's a radial tyre. 15 is for a 15" rim. A FR78 15 is approximately equivalent to a [url=http://tireguides.com/print_friendly2.asp?.
The alpha numeric size tyres where about load ratings. The letter dictated how much load a tyre could carry. Stupid american attempt at sizing. Wish they would just get with the metric system....
Camels have nice toes
Post Posted: Fri Jun 24, 2011 2:32 pm
Dave
don't believe tyre placards, they are adjustable... :lol:
Users browsing this forum: No registered users and 1197 guests
