Joined: Tue Mar 08, 2011 8:22 am Posts: 48 Location: Burpengary
Posted: Sat Apr 30, 2011 9:30 am
How do you mean revs light up. I have no plugs they have cut the plugs off the old loom and just have terminals. There is off one plug a black wire and blue in the one loom then the other is 2 black wires. These 2 are nearly side by side on the left hand side
Reverse is the only one you need hooked up.. It is on top of the gearbox close to the bellhousing and points toward the passengers top door hinge... Should be red and yellow wires on both the loom and the switch.
Users browsing this forum: No registered users and 97 guests
