It is currently Mon Nov 02, 2026 11:05 pm
Post Posted: Sun May 01, 2011 10:38 am
i want 31s on my zuk, im putting a 2'' lift on it, and probly a 2'' body lift so the tyres dont rub, what do you do about extending the steering colum tho, and do i need bump stop extentions? sorry bout the neby questions but i searched it and not a hole lot that was usefull came up
Paul
Vehicle: 4wd
Post Posted: Sun May 01, 2011 10:40 am
With 2" lift and 2" body lift with a bit of beating and removing the out riggers you shouldn't need much bump stop extention if any at all.
Watch out or you'll get sued.
Vehicle: Yamaha scooter, 50cc
Post Posted: Sun May 01, 2011 10:42 am
I didn't have to do anything with my steering column when I fitted my body lift. The only minor issue I had was the hole in the transmission tunnel fir the stubby lever, wouldn't let the lever stay in low range, easily fixed with the lump hammer tho
Post Posted: Sun May 01, 2011 10:47 am
X2 for both those responses. I've fitted at least a dozen 2" BL's on sierras and never had a problem with the length of the steering shaft.
You won't need bumpstop spacing to run 31's with a 2" BL.
Post Posted: Sun May 01, 2011 11:11 am
if you need a steering column shaft try and find one of the collapsable ones and drill out the plastic pins
josh AKA Bazook
Vehicle: Vitara
Post Posted: Sun May 01, 2011 11:39 am
Alot of the kits I've seen have come with a steering colum spacer. http://cgi.ebay.com.au/Suzuki-Sierra-Bo ... 3f08f24521
Repping it, High Top style!
Post Posted: Sun May 01, 2011 10:30 pm
If I remember correctly, zukofhzrd was thinking of getting some stuff like t/f case gears and body lift from the states, so I assume from lowrange. Their kits come with all the mounting hardware needed but no steering column spacer, this is the kit I bought an you don't need a spacer for the steering column as there will be no issues
Post Posted: Sun May 01, 2011 11:09 pm
ok kool, so bump stop spacers are just so the bigger tyres dont scrub on the body, is that right?
yer seen that one on ebay and thats what made me think if some kits come with them mabye it would be a problem and yes nato78 is right ill probly be getting most of the gear from the states and there kit dosnt come with the colum spacer
Post Posted: Sun May 01, 2011 11:59 pm
Basically yes.
Post Posted: Mon May 02, 2011 2:16 am
hmmm i fitted my new body lift not sure if iv done it right haha .. think if got a little more then 2 inch .. anyways my fuel filler hose has poped off the end ..
Post Posted: Mon May 02, 2011 2:17 am
Pics?
Users browsing this forum: No registered users and 181 guests
