It is currently Wed Nov 04, 2026 10:43 am
Vehicle: 91 WT 1.6EFI
Post Posted: Mon May 02, 2011 4:43 am
is there a trick to getting the two screws at the back of the starter solenoid out? I just spent two hours with wd40 and a cold chisel and it hasn't moved
Vehicle: SJ80, SE416
Post Posted: Mon May 02, 2011 4:48 am
I have removed one with a supercheap impact driver before. If the screws are still intact I would try and impact driver and a heavy hammer. They aren't expensive either (although cheap ones twist/break bits regularly).
EDIT: http://en.wikipedia.org/wiki/Impact_driver
Post Posted: Mon May 02, 2011 4:51 am
How did you fit an impact driver between the engine and the fire wall? I can barely get a screw driver and my hand in there
Post Posted: Mon May 02, 2011 4:54 am
Remove the starter first...
Post Posted: Mon May 02, 2011 4:55 am
just pull the starter motor out, will be heaps easier
Is that just a couple bolts around the engine?
Post Posted: Mon May 02, 2011 4:57 am
theres 2 bolts going through the bell housing that hold it on + disconnect the 3 wires attached to it. doesn't take long.
Post Posted: Mon May 02, 2011 6:32 am
thanks guys got it all sorted. managed to get the screws out with a hammer and screwdriver. no way could I have gotten them out with the starter motor in. :)
Vehicle: 2018 DMAX
Post Posted: Mon May 02, 2011 6:43 am
That solinoid took some bloody muscle and WD40 to get off the other starter. Thats what 20 years of moisture will do to them.
Post Posted: Mon May 02, 2011 6:56 am
I'm hoping that is the last one I'm going to have to replace. big hands and a little engine bay dont go.
Users browsing this forum: Google [Bot] and 138 guests
