http://auszookers.com/forum/
Replacing starter solenoid
http://auszookers.com/forum/viewtopic.php?f=5&t=21547
Author:  Rossco [ Mon May 02, 2011 4:43 am ]
Post subject:  Replacing starter solenoid
is there a trick to getting the two screws at the back of the starter solenoid out? I just spent two hours with wd40 and a cold chisel and it hasn't moved
Author:  Reubs [ Mon May 02, 2011 4:48 am ]
Post subject:  Re: Replacing starter solenoid
I have removed one with a supercheap impact driver before. If the screws are still intact I would try and impact driver and a heavy hammer. They aren't expensive either (although cheap ones twist/break bits regularly).
EDIT: http://en.wikipedia.org/wiki/Impact_driver
Author:  Rossco [ Mon May 02, 2011 4:51 am ]
How did you fit an impact driver between the engine and the fire wall? I can barely get a screw driver and my hand in there
Author:  Reubs [ Mon May 02, 2011 4:54 am ]
Remove the starter first...
Author:  crewsy [ Mon May 02, 2011 4:55 am ]
just pull the starter motor out, will be heaps easier
Author:  Rossco [ Mon May 02, 2011 4:55 am ]
Is that just a couple bolts around the engine?
Author:  crewsy [ Mon May 02, 2011 4:57 am ]
theres 2 bolts going through the bell housing that hold it on + disconnect the 3 wires attached to it. doesn't take long.
Author:  Rossco [ Mon May 02, 2011 6:32 am ]
thanks guys got it all sorted. managed to get the screws out with a hammer and screwdriver. no way could I have gotten them out with the starter motor in. :)
Author:  boostedbrick [ Mon May 02, 2011 6:43 am ]
That solinoid took some bloody muscle and WD40 to get off the other starter. Thats what 20 years of moisture will do to them.
Author:  Rossco [ Mon May 02, 2011 6:56 am ]
I'm hoping that is the last one I'm going to have to replace. big hands and a little engine bay dont go.
